  4. So Close!...
So Close!...
1.1k Posts 26 Posters 666.0k Views
    Gudgeon pins are a snug fit right?
      #782
      Yeah, I think so. The Athena one actually has chamfered edges that mate up tight with the C clips. It’s so tight I think it keeps the C clips in place when it gets hot…
      I just spent my afternoon taking off a MM (from my 57MM pin) with an angle grinder. I then had to do the chamfered edge on both sides. I used a fat + head screwdriver, let the pin spin on the end of it against the angle grinder…
      Not pretty but it works out OK 😉 …
      My only wonder is that the pin I have is over twice as heavy as the Athena one. One part of me thinks the extra weight will be ‘torque-y’ when it’s spinning. The other worries about it being out of balance with the balancer shaft! 🤪
      Or is it the weight of the crank that it balances?!…
        Well that's why people were not a big fan of Athena 170 kit because of the extra weight causing additional vibrations...
          So it’s the piston that the balancer shaft balance’s? I’d of thought Athena or some other enterprising soul (with access to a lathe) would of made up and sold a batch of ‘big bore balancer bits’ by now! 🙂 …
          I thought it was the crank, for some reason…
          CalumC MadGyverM 2 Replies Last reply
            @SpookDog 🤷 Mine does vibrate a fair amount on longer rides my hands go numb. It's just something I've learned to live with for the times that I use it. That said, it's my understanding that the Rotax 127 engines, fitted to Aprilia AF1s, didn't even run a balancer shaft 😛
              Yeah, I get numb hands with the 125! Jelly fingers from Hell!…
                MadGyverM
                MadGyverM
                MadGyver
                Or you can use the DT200R 3ET balancer that fits like a glove,but then you are limited to the big bore kit along the heavy gudgeon pin you have.
                It's a mod I thought to do but I didn't have the vibrations I expected.
                • MadGyverM MadGyver
                  @MadGyver
                  I like your thinking! Nice idea, cheers bud…
                  I kinda thought that the numb fingers was an age thing anyways. I can remember driving Mk1 transit LWB with no power steering & drum brakes back in the 90’s.
                  Vibration is a minor niggle really 🙂 Saying that I’d rubber mount the bars if I could!…
                  Anyone got a spare clutch cable mount that lives on the bottom of the barrel stud that they can post? I’m skint till next Wednesday…
                    @MadGyver
                    HOTSHOT IIIH
                    HOTSHOT IIIH
                    #789
                    This post is deleted!
                      @MadGyver
                      #790
                      Damn it! I didn’t realise that there is an oil seal under the 2T pump drive cog, on the inside of the clutch casing. Every other bloody seal is listed apart from that one! 21 x 10 x 5
                      Got to wait for one to turn up now before I can button up the clutch casing…
                      I’ve replaced every other seal & bearing, so I’m not going to use the old one!…
                      Sometimes it feels like the ‘Little people’ are fuxin with me! 🧚‍♀️ …
                        HOTSHOT IIIH
                        HOTSHOT IIIH
                        @SpookDog I think you get one of those with the Yambits oil pump repair kit
                        • HOTSHOT IIIH HOTSHOT III
                          @HOTSHOT-III
                          Can you please link me to it? I’ve tried but can’t seem to ‘find anything’ 😐
                          I’d like to know what price is on the kit, as well as what’s included…
                          I’ve already gotten the casing oil seal. I don’t want to put on any of the pumps I’ve got without giving them a ‘refresh’ though!…
                            @HOTSHOT-III
                            #793
                            Don’t worry! I’ve found it 2 minutes later! 🤕
                            If the rain holds off for the next day or two: I should be able to fit the seals and button up the clutch side. I’ve already prepped it with a hot detergent wash and ‘scrub/brush’ it’s just degrease assemble and fit. Same with the barrel and piston. I’ve already decoked the piston and PV and barrel-exhaust port…
                            I haven’t found suitable bolts for the reed cage and inlet yet. I won’t fit the top end till that’s fitted and plugged with clean cotton waste…
                            One good day or two ‘meh!’ days and I’m ready to give the bike a few soaks with shampoo detergent before getting a final jet wash. Then I can swap out the motors while fitting a new (used) rear shock…
                            I still haven’t finished fitting the bottom headstock bearing to the replacement yoke! It got stuck halfway and I didn’t want to force it ‘unreasonabley’ 🙂 I can’t throw anymore heat at it because it’s got a built in oil seal! So, because I don’t know anyone with an hydraulic press, I need to find a suitable sized tube to ‘beat it on squarely’ 😜
                            I’d kinda gotten used to the ‘clicky’ front end because it tracked truly, unlike before when it used to favour a few degrees to the left or right ‘Unsafe at any speed over 40’ springs to mind!…
                              Any tips on fitting the Athena head? Is the inner cap supposed to be a tight or a loose fit? It took a bit of heat to separate it from the outer head-cap. I’d imagine that it’s a ‘good’ fit that is held in place by the rubber seal around the spark plug section?
                              Be nice to know tho! 😜 …
                                The athena head drops into the skull cap as a snug fit, then miraculously becomes a nightmare to remove 🤣 At least that was my experience.
                                  #796
                                  Cheers bud! That’s is actually very helpful!…
                                  OMG! I have fallen in love with Permatex Copper gasket spray! Why haven’t I found this before? It really is the mongrels dangles! Perfect application 😇
                                  • MadGyverM
                                    MadGyverM
                                    MadGyver
                                    #797
                                    @SpookDog Permatex Copper gasket spray,if needed It can be easily removed with nitro thinner.
                                      @MadGyver
                                      Nitro, What is dat? Model fuel?…
                                      S MadGyverM 2 Replies Last reply
                                        @MadGyver
                                        #799
                                        Do the piston rings go a particular way on an Athena piston? I can’t see any difference between them. The only thing that might be a marking is a [ kind of shape, but horizontal. That’s only on one ring though…
                                        CalumC S 2 Replies Last reply
                                          @SpookDog No? I just put them in so that the text was facing upwards and that the ring end gaps met the dowels in the piston grooves.
                                          Wossner are notorious for leaving one of the ring end gaps out of spec, gives the fitter flexibility to dial it in. The Athena ones I done recently were both spot on, but needless to say, you should check it against the spec.
