  4. Flywheel puller
Flywheel puller
4 Posts 3 Posters 860 Views
    jonne123
    What is the right size puller for dtr 125 flywheel? Model F3NC 001ZD
      This is for the older engines
      https://www.ebay.co.uk/itm/FLY-WHEEL-PULLER-REMOVER-EXTRACTOR-YAMAHA-PW-YZ-DT-YZF-TT-XT-50-80-85-125-240-50/272304989305?hash=item3f66a46479:g:ygoAAOSwGvhT14ys
      This is just a universal jobby. Been good enough for me.
      https://www.ebay.co.uk/itm/HARMONIC-FLYWHEEL-47PCTOOL-KIT-BALANCER-CRANKSHAFT-BALANCER-GEAR-PULLER-PULLER/254516212226?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
      J 1 Reply Last reply
        jonne123
        @Calum thanks but how would you use the bottom one?
        • J jonne123
          @jonne123
          You bolt it to the flywheel, then insert the centre bolt and tighten it. You need to of removed the centre nut first though...
