  3. Brakes
  4. 320mm Upgrade \\ HELP
5 Posts 4 Posters 1.3k Views
  • K
    K
    KarumasPT
    Hi there!
    I have a DT125 RE with a oem fork, but 17"17" wheels ( DTRE\DTR HUB)
    But i want to put a 320mm brake disk.
    Any ideias for a disk plug-n-play on the DTR hub?
    How do you guys do it ? and the caliper suport ?
    Tks
    Or other hub\wheel solution 17" that fits in DTR oem forks
    Glynn123G NINJAN 2 Replies Last reply
    • K KarumasPT
      Hi there!
      Tks
      Glynn123G
      Glynn123G
      Glynn123
      @karumaspt I had this problem with my DTX SM wheels when I fitted USD forks. I’m almost certain you cannot get a 320mm disc with the same stud pattern and PCD as the DT hub unfortunately, the biggest I could find was the DTX/WRX disc which is 300mm if I remember right. You’ll have to make your own calliper spacer aswell as I don’t think anybody makes them off the shelf for this platform, but there is a drawing with dimensions that used to float around the forums and it’s not too difficult to make.
      • NottsbikerN
        NottsbikerN
        wrote on last edited by Nottsbiker
        From memory I'm not aware of any direct swap discs for the DT-R hub so would assume that you need to have one custom made for the job. I have the same issue with my DT200WR as it uses a unique front hub that no other bike does so tune up parts are non-existent.
        The front hub from the Italian TDR125 holds a 320mm Brembo disc but would need lacing into your rim unless you want to stick with the TDR's 18 front wheel.
        Personally I'd either go with the DT-X front forks or get a disc custom made along with caliper mounting bracket.
        K 1 Reply Last reply
        • K KarumasPT
          Hi there!
          Tks
          @karumaspt Post some pics dude.
          • NottsbikerN Nottsbiker
            K
            K
            KarumasPT
            @nottsbiker im from portugal, and the dtx forks + hub ( or complete wheel ) are very very expensive
