  3. Carburetor
  4. Dtr 2001 hose warming pipes
6 Posts 6 Posters 1.1k Views
  • J Offline
    J Offline
    jjay5947
    Do I need them connected to my bike at all
    S NottsbikerN 2 Replies Last reply
    • J jjay5947
      @jjay5947
      To the carb? No, but it is there because it helps. Especially this time of year 😜
      M 1 Reply Last reply
      • J jjay5947
        NottsbikerN Offline
        NottsbikerN Offline
        @jjay5947
        Normally no but if you ride in very cold weather they prevent the carb from icing up, which in turn could result in the throttle sticking on
          @jjay5947
          M Offline
          M Offline
          Michaelashbrook
          @SpookDog hi mate, how do the warmer pipes go through the carb
            The original Mikuni had two feeds on either side that you connect via the cylinder head.
            I've never bothered in 15+ years of DTR ownership.
            • M Michaelashbrook
              @Michaelashbrook As others have said it doesn’t make any difference which hose goes where, and they’re not really needed in a country like the UK with mild winters. However they also serve another purpose which is to make the cooling system self-bleeding when refilling as the one on the thermostat housing comes out above the actual thermostat, so all you have to do is fill the radiator slowly and you end up with no trapped air (this is why bikes like the 350LC and a lot of MX bikes have bleed bolts on the head and barrel etc.). So it’s useful to just run a single hose from one banjo straight to the other and bypass the carb; you still retain the self-bleeding cooling system but it’s a lot easier to get the carb off for cleaning, jetting and float height changes etc.
