  4. Different power valves
4 Posts 4 Posters 1.5k Views
  • J Offline
    J Offline
    jimmydc98
    Does anyone know if these 2 are compatible in the same cylinder they both say 3bn and the one without the o rings next to the exhaust came from a 3mb cylinder
    There is also a variation on the powervalve head I presume the diamond shape was mainly on UK models with the fixed powervalve so they could restrict power and then you could change it yourself from the 2 different settings where’s the rectangle one would only go in one way but I may be wrong
    DT200WR 1997 - New Project
    DTR 125 2002 - Project
    DT 125 LC 1986 - Old Bike
      I know the powervalves you get from the 3BN cylinders are not interchangeable with other cylinders.
      Those valves look wildly different so I'm not confident to say they both fit properly.
      • J jimmydc98
        @jimmydc98
        The diamond shape is irrelevant, the power valve never had a servo pulley fitted to it. You can position the valve where you want then tighten it up with the end bolt. If you fit a servo you need to change the ( gear lever side) bush to allow for rotation. Otherwise it clamps the power valve...
        • NottsbikerN Offline
          NottsbikerN Offline
          As mentioned the diamond shape fits the pulley with the square / rectangular end as well
          The grooves in the power valve aren't for O-rings, instead these fit into the ends caps as you cant refit the valve into the cylinder with O-rings in the grooves 😉
