  4. Rubber mushrooms for engine case bolts
8 Posts 5 Posters 3.3k Views
  • D Offline
    dan28
    What are the rubber mushroom things called that the screws for the engine case sit in
    D N 2 Replies Last reply
    • D dan28
      dan28
      @dan28 Mine are perished is it ok to remove them
        I literally cannot think of what you are speaking about!
        • M Offline
          M Offline
          mezzaaa
          I know what you mean try fowlers there a little black rubber but that goes in the case before you put bolt in
          D 1 Reply Last reply
          • M mezzaaa
            dan28
            @mezzaaa said in Rubber mushrooms for engine case bolts:
            Yes that's what I meant
            • R Offline
              R Offline
              Raydt
              I want to know what these little rubber bits are as well because they must be missing on mine.
              • D dan28
                @dan28 said in Rubber mushrooms for engine case bolts:
                Perhaps some photo's might solve the mystery??? ;O)
                  WHat number
                  https://www.yamahamotorcyclespares.co.uk/spares/epcImages/9028/9.jpg
