  3. Suspension
  4. Swingarm and shock bearings and bushes
21 Posts 5 Posters 9.5k Views 1 Watching
  • D
    DTGREENLANER
    Hello
    Went to replace swing arm bearings with silky kit but turns out the suspension linkage and mate says looks like play at the bottom of the rear shock too?
    I can see on Fowlers the DT125R shock have collars within the bottom of the shock but not in the newer models. I have the DT125X but I know some parts have been swapped about…
    Can you see from the photo if that’s a DT125R shock and are they the collars which you can see?
    If they are I’ll order them as well but hes wondering how does he go about removing them to change please? They seemed pretty stuck in there
    Cheers
    )https://ibb.co/Y30rL94
    https://ibb.co/0Yc6CvV
    https://ibb.co/ZhwttMN
    S MadGyverM 2 Replies Last reply
    • D DTGREENLANER
      Hello
      Cheers
      @DTGREENLANER
      Never removed them but I imagine it’ll need heat!...
      Did you get just the bearings? Or the whole kit with bearings, nylon bushes and steel inners, and oil seals?...
      You really need to do the whole lot at the same time. Linkage bearings, bushes and seals included...
      PS the swing arm end cap seals and shims as well!...
      Good luck! 🙂 ...
      D 1 Reply Last reply
        @DTGREENLANER
        Good luck! 🙂 ...
        DTGREENLANER
        @SpookDog
        We tried heat on it and my mate who's quite clued up with engineering and that gave up on it till we found out best way or till the other parts turn up….
        Yeah we ordered the slinky kit but that’s only got the actual swing arm bearings bushes and seals don’t it…so we got to order everything else separately, like the Swingarm linkage bearings and that.
        This gonna end up quite costly lol
        • D DTGREENLANER
          @SpookDog
          @DTGREENLANER Yes, the swinging arm bearings can be quite costly.
          Sourcing the bearings indepently from somewhere like Simplybearings can save you a fair chunk of change.
          I could have sworn the bearing sizes were all listed here!
          • D DTGREENLANER
            Hello
            Cheers
            MadGyverM
            MadGyverM
            MadGyver
            @DTGREENLANER
            I had changed mine with a vice and some random size metal tubes for spacers.
              DTGREENLANER
              wrote on last edited by DTGREENLANER
              Yeah seems that way.. that will teach me for keep taking it offroad lol… I own these as well but luckily they don’t cost me much money either normally 😂 I’m just gonna have to bite the bullet and get it done soon… 😂
              [url=https://postimg.cc/mPkmg3jr][img]https://i.postimg.cc/mPkmg3jr/198-F7334-4-FF5-41-F6-917-B-D0-FD8-CEB472-E.jpg[/img][/url]
              [url=https://postimg.cc/N5pNtC1V][img]https://i.postimg.cc/N5pNtC1V/52100-A91-0-E22-4530-8390-4-B2-F7918-AF7-F.png[/img][/url]
              Ah right cheers, yeah I had a look for sizes but couldn’t find anything…
              • MadGyverM MadGyver
                @DTGREENLANER
                DTGREENLANER
                @MadGyver
                Cheers the ones in the shock mate yeah?
                MadGyverM 1 Reply Last reply
                • D DTGREENLANER
                  @MadGyver
                  MadGyverM
                  MadGyverM
                  MadGyver
                  @DTGREENLANER
                  Swingarm,arm relay and shock,every bushing or needle bearing was pushed out and the new pushed in.
                    @DTGREENLANER
                    DTGREENLANER
                    @MadGyver
                    Ok thank you mate. We’ve got the Haynes manual now so should be alright lol cheers
                    • D DTGREENLANER
                      @MadGyver
                      DTGREENLANER
                      @DTGREENLANER
                      Only just getting round to doing this lol
                      When it comes to putting everything back together is it necessary to torque everything up or can we get away with out?
                      If we do need to torque can anyone provide torque measurements for each bolt. I’ve marked them up ABCD and would need for top of shock as well and that will be E lol.
                      Cheers
                      https://ibb.co/zrdL7NX
                      • D DTGREENLANER
                        @DTGREENLANER
                        Cheers
                        DTGREENLANER
                        @DTGREENLANER
                        Also at the bottom of the shock between two bushes turns out there is an olive not on the parts diagram and seals?
                        Do you know anything to help us get this sorted? I.e how to get seals and new olive in the middle, (bottom of shock)
                        Is this an aftermarket shock? Because diagram don’t show up these???![alt text]([image url](link url))
                        https://ibb.co/TkJ4Cr2
                        https://ibb.co/PgM4LY9
                        https://ibb.co/dgzKvzR
                        https://ibb.co/mvw35Z0
                        • D DTGREENLANER
                          @DTGREENLANER
                          DTGREENLANER
                          @DTGREENLANER
                          https://ibb.co/mNmysh5
                          This is the shock I thought had fitted but like i say doesn’t have olive and seals??
                          The shock is marked up as “SACHS”
                          Please can anyone help lol?
                          • D DTGREENLANER
                            @DTGREENLANER
                            @DTGREENLANER
                            Got a picture of the shock? I don’t know anything about DTX shocks but the Dtr shock has a ‘ball’ swivel bit inside the bottom mount...
                            Dtr settings are:
                            Rear suspension unit nuts: 3.3kgf m
                            Swing arm nut: 9.0 kgf m
                            Linkage nuts are all 5.8kgf m
                            Hope this helps some...
                              @DTGREENLANER
                              Dtr settings are:
                              DTGREENLANER
                              @SpookDog
                              Thanks for the torques settings mate
                              Here’s links to the SACHS shock photos and half of it pressed out. My mate says we might struggle to find similar bushes as it has rubber on the inside and splines on the end to keep it in place into the olive and need replacement seals.
                              Does seem looking online more that it looks very likely that the dt125re / X was supplied with this shock from factory. But when looking on parts diagrams it’s different and doesn’t mention any of these bits so that I could easily go buy them?
                              Have you got any ideas mate?
                              Have thought about sourcing a second hand dt125 re SACHS shock, but they could be worn too and would be unable to source the bits in future?
                              I can see online that dt125r shock is completely different in dimensions but will fit an RE frame? But even then on the parts diagram to them it doesn’t show that ball swivel you mentioned, just two bushes each side?
                              https://ibb.co/KWr8FrF
                              https://ibb.co/fQHptzn
                              https://ibb.co/0mBNYMZ
                              https://ibb.co/dM2ggJV
                              https://ibb.co/0Cp65mX
                              https://ibb.co/dKq8JKV
                              • D DTGREENLANER
                                @SpookDog
                                @DTGREENLANER
                                It all depends on how rich you are 🙂 an after market adjustable gas shock is £250~300. A Dtx shock will probably be hard to find. I’ve yet to see a Dtr shock with shot to F bushes. I don’t know why a late model dtx would wear so early. What mileage you got? I’m on 34000 with fine condition bushes...
                                I do have a spare Dtr rear shock I could lend you to check fitting, then a second hand Dtr shock is easy to find and not expensive , £30~50...
                                EDIT
                                RE 2008 model shock for £50 on fleabay , says Sachs on it I think. Put the number in fleabay search:
                                304693115806
                                  @DTGREENLANER
                                  EDIT
                                  304693115806
                                  DTGREENLANER
                                  @SpookDog
                                  Haha I’m trying to save good for a house and already got a newish golf and a ninja 600 to look after as well so won’t be buying no gas shock unfortunately lol.
                                  Ah thank you for the offer mate and for you looking yourself to find me a second hand one! Very kind of you man
                                  I’ve had a look at that RE one on ebay , messaged him to make sure the bushes feel nice which he says they are so I’ve gone and bought it so I don’t have to faff about any more trying to solve this lol. Thanks again man!
                                  I got an aftermarket speedo and speedo don’t always work (wish I kept original but was young and stupid lol) but I reckon it’s only on around 15k lol! I have taken it offroading a lot though in the past 😂 had the bike getting on 12 years now lol
                                  Let’s hope this shocks all good then just gotta do some of the other bushes with my mate then it will be good to ride again
                                  Cheers
                                  • D DTGREENLANER
                                    @SpookDog
                                    Cheers
                                    DTGREENLANER
                                    @DTGREENLANER
                                    Alright guys me again lol, replaced pretty much everything rear suspension wise including linkage bushes and seals using genuine Yamaha parts apart from wemoto slinky kit for arm but there is still is the slightest up and down play in the rear arm?
                                    Is it normal for a tiny bit of up and down play or is it worth stripping down again and investigating?
                                    Wondering if my mates torque wrench could be out of sync too?
                                    Not up for years time being loads of play again lol
                                    didn’t replace the dog bone bolts as they seemed all good, and bushes on shock were tight
                                    Cheers
                                    • D DTGREENLANER
                                      @DTGREENLANER
                                      Cheers
                                      @DTGREENLANER no if it's all done up to spec there should be no play. That's usually one of the first things I check come MOT time, hoist the bike up and over onto the side stand and check the rear arm for play.
                                      • D DTGREENLANER
                                        @DTGREENLANER
                                        Cheers
                                        HOTSHOT IIIH
                                        HOTSHOT IIIH
                                        @DTGREENLANER Did you replace the relay arm needle roller bearings where the linkage attaches to the frame?
                                          DTGREENLANER
                                          Ok mate cheers
                                          Well I won’t bother riding it and we’re go over it again in the week and see if we can get it to zero play.
                                          Cheers
