  4. Let’s talk clutch cables
8 Posts 5 Posters 1.4k Views
  • M Offline
    M Offline
    mhbikesnbits
    Just curious what people think of the after market clutch cables for the dt, have you used any ? If so what do you recommend
    • M mhbikesnbits
      @mhbikesnbits Only use genuine lol
      I had no end of problems with aftermarket ones.
      Apparently SlinkyGlide are supposed to be good quality though.
      M 1 Reply Last reply
      • M mhbikesnbits
        Same as calum genuine if possible I've had my dt many years and still don't have a proper clutch cable the cheap ebay ones didn't even remotely fit my bikes still using a clutch cable from a 50cc motorbike it works okay with a spacer I will get round to getting one eventually
          M Offline
          M Offline
          mhbikesnbits
          @Calum it’s just getting hold of a genuine one , a nos one like may look into the ones you’ve just tagged tho cheers
            M Offline
            M Offline
            mhbikesnbits
            @declan ahh cheers for the heads up will stay away from the eBay ones then
            • M mhbikesnbits
              @mhbikesnbits
              I’m using a Slinky and it’s actually not bad. It is very unrestrictive and easy to channel. It’s super flexible...
              In my very limited experience I would recommend it...
                @mhbikesnbits
                M Offline
                M Offline
                mhbikesnbits
                @SpookDog ah great thanks for the opinion Might give one ago for a tenner
                MadGyverM 1 Reply Last reply
                • M mhbikesnbits
                  MadGyverM Offline
                  MadGyverM Offline
                  MadGyver
                  @mhbikesnbits I am using a genuine one,old NOS if I recall correctly.I have made a modified backup from an XT600 (early model that has the clutch arm on the same side as the DT) was used but in excellent condition.
