  3. Carburetor
  4. DTR 125r 2000 full jet refurb Advice
17 Posts 4 Posters 6.0k Views
  • primal carnageP
    primal carnageP
    primal carnage
    wrote on last edited by primal carnage
    Re: Dep exhaust jetting
    i have bought a 2000 DT125R ie DTR... so the carb was hammered the gaskets were snapped theres a slight ring round the rubber needle end that goes in the needle seat so i have ordered a fresh carb refurb kit ..Any way the bike has a brand new full DEP system stage 2 DEP shorty also new...bikes mint i just find when i pull off it takes like 5 seconds for the valave to come in or in top end takes awhile for it to come in ..but if i double clutch it in 1st brings it in quicker but dont wanna fcuk me bike..its also full powered don't know why people say that like a good thing coz it just means my servo cables have been took off and valves pinned open. Even though i got the bike like this i don't mind as i have had loads that have been pinned open and its made no difference at all infact i have had more power in the past..So i have tried a 260 jet was useless im running a 220 atm but when i get this new kit do you think the 240 will be good enough as i know all new pins and valves and seals will make a difference to start with ..should i leave the 220 on see how it goes or should i be looking more towards the 240 so i dont have that wait for the valves to come in ..it only does it in first for a few seconds but in last gear can take 2 or 3 mins to get to 80 mph coz i have to wait...any advice will help thanks i read different things all the time some say 220 is standard and some say 240......or do you think it will be the ring round the rubber needle and old jets that are making it take awhile to pic up and just leave the 220 jet in ? The pin seat was sized in so had to use a revers drill bit and a screw to pull it out so theres a good tip for anyone with a sized seat get it out lol without damaging ya carb but i need advice on the jet was it the old jets and rubbish gaskets or do ya think i need to go up a size thanks..
    • primal carnageP primal carnage
      @primal-carnage
      Sounds like a 240 main jet is needed. The easiest way to tell is look at the pilot jet size, if it’s a 25 jet you want a 240 main jet (needle clip a 4th lowest groove) If it’s a 22.5 pilot then you want a 210 main jet...
      If your bike has a power valve servo fitted you are wasting low end torque by having it disconnected and pinned open. Pinning open the power valve on bikes fitted with servos doesn’t de-restrict them, as the servo opens the valve fully at higher revs. De-restriction methods depends on year of bike but include:
      Pinning open power valve on early bikes without servo fitted
      Moving sensor from back of rev counter
      Removing tube from inside exhaust inlet on some models
      I’m not very knowledgable on later bikes as mine is a late 1988 model that never had a servo fitted to the power valve...
      P.S. Congrats on owning a piece of 2stroke history 😜
        210 main jet is fine for the carb, that's even what DEP themselves recommend.
        Your problem lies with your powervalve being pinned open. This isn't "Full Power", as SpookDog said, you're just losing out on bottom end.
        The problem is, the 2000-2004 DTR Models are some of the worst in terms of restrictions, namely the CDI which is probably why the valve has been pinned.
        Your best bet would be to source an earlier 3-RM CDI, or go buy a Zeeltronic/Ignitech aftermarket ignition system which will allow to to fully utilise the powervalve servo
        Before you do that however, you need to understand the bikes condition. There becomes a point that after so many rebores, you won't be able to run the powervalve due to clearances with the piston. If you're reaching that limit, then fitting the servo could cause the piston to hit the valve causing catastrophic engine failure.
        I believe it's at 2.00mm overbore you need to modify the powervalve to avoid fouling the piston, then there is some overbore after that where running a valve simply isn't possible.
        markus.wM 1 Reply Last reply
          markus.wM
          markus.wM
          @Calum the UK model is restricted and has a 210 main jet and 17.5 pilot jet as standard. The French imports (as many are) are not restricted and are fitted with a 240 main jet and 25 pilot jet from 1999 onwards. The later DT125RE/X came in 210/17.5 restricted from only.
            markus.wM
            markus.wM
            @primal-carnage is it a UK or French model as jetting is different for both? Also your model year has the reed switch restriction in the back of the speedo.
            primal carnageP 1 Reply Last reply
            • markus.wM markus.w
              @markus-w I wouldn't say "restricted" at "210". The DEP Pipe is a performance pipe and as I say, not even recommended to up the main jet.
              Restricting the fueling is unsafe and dangerous to the engine. It might be that climate favourited 240 main jet. In any event, jetting should be done to suit, and the best bet for nipping performance on those later DTRs lie in the CDI and getting that powevalve working.
              S markus.wM primal carnageP 3 Replies Last reply
                Yeah, they wouldn’t have separate jetting for restricted and un-restricted models. They all drink from the same cup 👍
                The carb bodies are different for year and country (apparently!) and are so jetted differently...
                I think it’s important to establish the proper jetting for the year of the carb, or the country of origin and year, apparently! They are not all the same base model...
                  markus.wM
                  markus.wM
                  @Calum yes they have different jetting among many other things. I know you don't have to up jet when fitting a DEP exhaust but to fit a 210 on a French model would be down jetting. It's important to know which model one has when jetting. I've heard people recommend to 'upjet' to a 220 but on a French model that would be wrong.
                    markus.wM
                    markus.wM
                    @SpookDog that's exactly what I said bud. One can't recommend a 210 main jet on a 2000 French import that was fitted with a 240 standard. It's important to establish what model one has first.
                    S primal carnageP 2 Replies Last reply
                      @markus-w
                      Then we’re all kinda on the same page, no? It’s all too easy to misinterpret text because it has no...? Context?! I don’t know! People only know what’s written, not what was meant...
                      Anyhoos, no offence meant...
                        primal carnageP
                        primal carnageP
                        primal carnage
                        @markus-w yeah mine isnt a french import mate so i have orderd the 240 jet with the kit i have tried the 260 and it borked up the road ..but im thinking from a 220 to a 240 will do the job the lad said befor he put the full dep on it was running fine ..i have to say it does run ok but in 1st it just takes 5 seconds for valve to kick in ......i think after xmas ill be putting it in the shop to get valves fixed
                          primal carnageP
                          primal carnageP
                          primal carnage
                          @markus-w now then mate yeah mines not a import mate i only got it last week i just know the carb was rotten so i have sorted that just waiting on fresh re furb kit ...i think a 240 jet will do the job tbh its nbearly there now i get 80 out of it but last gear can take time to kick in
                            @markus-w
                            markus.wM
                            markus.wM
                            @SpookDog none taken bud. It's all good. Did you get your exhaust yet from Portugal?
                              @primal-carnage What do you mean "valve to kick in"?
                              You said it's pinned. So it's an open port and therefore the valve isn't doing anything. Do you mean, it takes time for the powerband to kick in?
                              In which case, as previously said, restore the powervalve to fix that issue. There is nothing to be gained from pinning it, only to lose. This can easily be remedied.
                                @markus-w
                                Cheers bud! Wires can get crossed all too easily with text messages.
                                Regarding the RH exhaust: Waiting for the man to send it ☹️ Should be this week 🙂 My bike is actually running really well for the first time! 4000 miles with no head gasket problem!! 👻
                                The pipe will be an absolute fuckin bonus!...
                                I think he means the power band, maybe? In which case something is drastically wrong! 1st gear should be almost instantaneous. A DTR125 should be doing 60mph in 5 or 6 seconds!...
                                Same old problem with a used bike, you have to set it back to standard. Fix the problem/s, then take it from there...
                                Check the pilot jet size please bud!...
                                  primal carnageP
                                  primal carnageP
                                  primal carnage
                                  @Calum now then fella can ya giz some more info on this switch ya on about on my speedo will that restrict my bike and can it be took off
                                    @primal-carnage Better to just reference @scrimsmustang
                                    http://www.scrimsmustangclassicyamahadtrestoration.com/derestricting-the-yamaha-dt125r-1988-through-to-2007.html
