  3. Other
  4. The Dionysus Project (Aprilia ETX 125 Rotax 122)
apriliaetxrotaxdionysus
48 Posts 7 Posters 22.0k Views
    Managed to source OEM indicators/mirrors (although not my taste personally).
    A fair chunk of change was dropped on renewing brand new OEM NOS throttle, clutch, choke, Odometer cables.
    I also decided to paint the mild steel arrow pipe. Just make it look like a factory pipe and nothing fancy.
    I must have bought this pipe brand new 3 years ago and it's been in storage since and even then it's rusting....
    It's no TYGA pipe for sure!
    Buzzing to get this bike complete though.
      🎆 YAY! 🎆
      What has been, three long years and the bike is finally on its own two wheels again.
      Trip down to the powdercoaters to pick up the suspension spring as it just didn't feel right to put the crusty one on there.
      I had it repainted the OEM colour for this bike, but fitted the RX/MX/SX shock absorber. It was refurbished to the best of my abilities.
      Sadly the bike isn't concourse and never will be.
      But it's starting to come together nicely now!
      And at least I can move it around the garage out the way of the other bikes finally!
      • R
        R
        rxsam95
        Cool build bud, where did you get the pipe from?
          Aprilia ETX Suspension Bushes Bearings
          Part No Dimensions Description Quantity
          AP8121815 12X26X12(16) GE12PW -SPHERICAL BEARING 1
          AP8110037 18x24x12 HK1 812-MB Major Brand HK1812 Drawn Cup Type Needle Roller Bearing with Two Open Ends 6
          AP8110067 22x28x16 HK2216-MB Major Brand HK2216 Drawn Cup Type Needle Roller Bearing with Two Open Ends 4
          AP8120809/AP8110068 18x24x3mm Nitrile Rubber Rotary Shaft Oil Seal Springless Design VC Style 6
          AP8163318 - Aprilia MX Shock Absorber
          856715 - Aprilia RX/SX Shock Absorber
          AP8135848 Aprilia RX 1995 Swinging Arm
          AP8121121 - Swinging arm pivot bush
          AP8105132 - Swinging arm pivot bolt
          Uses same suspension linkage & swingingarm pivot bolt.
          The swingingarm pivot bushes are the same and are also used in the Aprilia RS 125.
            Slow slow progress on this.
            Made a bit of a push on this the last couple of weeks.
            New Renthal chain fitted. Bought some nice Apico foot rests and refitted/bled the front brake system.
            No surprises, but the original brake caliper was shot, completely seized solid.I managed to source another one, but one of the pistons was stuck. Once I addressed that, I found I was unable to pressurise the system, the master cylinder was shot.
            These bikes share the same master cylinder as the Cagiva Planet, but I was unable to source one of those for a reasonable price. I ended up getting a KTM Duke 390 front master cylinder as the closest match I could find.
            Front brake now bled and working. Bought lovely Hel lines front and back. The rear master cylinder's wiring loom was shot to buggery. The banjo switch was all snapped and the wires were merely soldered onto the bolt.
            A new genuine bolt, wire harness restored, then I designed and 3D printed the cover to secure it all into place.
            Need to reattach the rear brake master cylinder fluid reservoir and see what surprises are in store for me for the rear 😮
            Hoping to continue to make progress on this as it's basically done. Just need to find original panels (or refurbish my ones for now).
              Reposting images as Imgur is no longer viable in the UK.
                wrote last edited by
                #47
                Slow slow progress on this...
                It's really not far off completion, I have been addressing the wiring harness as it was completely torn to shreds. It's all starting to come together now and it's good to see the lights come on after it being sat in the dark for 4ish years.
                I really feel as though it's getting close to rideable.
                There have been a lot of problems with pretty much every component, but brakes are now bled, radiators are plumbed in and it's almost ready for some fuel and it's first start.
                  #48
                  Probably worth mentioning, as you can see in the background of this photo, I have managed to acquire a fully supermoto setup for this machine as well.
                  These come off the Aprilia MX 125. Since I'm running an MX rear end, that should be simple enough to swap out, but the front end shows some challenges.
                  The MX125 front wheel uses a digital speedometer, so swapping out the front end means losing the speedo.
                  Instead, I managed to find a brand new old stock MX front rim, and I've also managed to source an RX125 front hub, so I will look to lace the RX hub onto the MX rim, thus retaining the original speedometer configuration. The rear wheel is in poor condition, the hub has snapped in several places, but I managed to find a brand new old stock MX rear hub, so the plan is to lace both wheels and have an easy to swap out setup for both road and trail riding.
