  4. engine piston check
engine piston check
73 Posts 6 Posters 23.0k Views 1 Watching
  • E
    E
    erion1
    i did a piston change before 7-8 months and the bike was losing coolant so i took it apart now and i saw that the piston had carbon built up under the piston rings
    is it a thing to wory about or not ?
    any help would be apreciated
      Two strokes don't benefit from pottering around. You need to give them a blast every now and then due to the oily nature of them.
      If there is a lot of carbon on the rings, then you'll get blowby and significant loss in performance, it's not irreversable or devasting, just dismantling it all and clearing the ring grooves and rings would probably address any issues. It all depends on how bad it is.
      • E
        E
        erion1
        wrote on last edited by erion1
        here is a picture of it https://imgur.com/gallery/KX8mVti
        and while it was on the cylinder the piston had a slight movement front and back it would tick a tiny bit
        • E erion1
          @erion1
          Get a rebore and new piston of the correct size 🙂 …
          • E
            E
            erion1
            the piston rings where all worn out and the cylinder has extremly slight scratch my nails go smoothly over them as there is none, maybe i can get a new piston the same size and just polish the cylinder what do you think?
            • E
              E
              erion1
              here are some pics,only now i realised they were scratched
              https://imgur.com/gallery/4C5Wk0J
              • E erion1
                @erion1
                It costs nearly as much to hone (not polish!) the cylinder as it does to rebore it.
                I don’t know how old your bike is or how many miles it has on the barrel, but they get oval after a time. Spending £100 on a rebore and new mitaka piston is the best money you’ll ever spend on your bike. When it’s rebored it’ll be a perfect fit.
                What head gasket did you do when you fitted a new piston? You say you had coolant loss?…
                Edit: it looks like you’ve had at least a partial heat seizure. Probably from the ‘loss of coolant’ head gasket blowing…
                S E 2 Replies Last reply
                  @erion1
                  You need a rebore and new piston. Use an Athena or vertex head gasket. Lap the top of the barrel and head before fitting, or get them done by the place that rebores it. What country are you in?…
                    @erion1
                    E
                    E
                    erion1
                    @SpookDog at the time that i did a piston change i did a rebore too bc my piston broke into pieces so its a 56.25, as for the head gasket it probably went bad it was never changed but the scoring on the cylinder i can't feel it with my finger or finger nails because i don't want to rebore it again,while the sylinder was still in the piston the piston hat a slight tap front and back,soo maybeee it will need a rebore for that bc it got oval but not for the scratches
                      @SpookDog Beat me to it, looks to me like a heat seizure also. You need to understand why you've had a seizure, otherwise spending money here is fruitless as it'll just happen again. Unless it needs a rebore, a hone may suffice, but my recommendation would be to let the engineering firm decide on what' appropriate. I had a bike stolen and ragged, the engineering firm said the bore ovalised but managed to get away with just a hone. The barrel went on for many trouble free miles after.
                      To reiterate @SpookDog's point, make sure you're using genuine/Athena/Vertex gaskets. The pattern ones, at least as far as the head is concerned, do not work and you'll just throwing money away. Understand why it failed and look to address this, otherwise prepare for failure again.
                      E 1 Reply Last reply
                        E
                        E
                        erion1
                        @Calum like i said the piston was brand new and i took both cylinder and piston for reboring it was perfect when i got it the only thing was that i used the old head gasket and that could of led it to seize.now,im saying that i will buy a new gasket and a new piston bc they have to be changed but i don't want to go on a bigger bore and if i can use the same piston size for the new one and hone the cylinder will it be fine with a new head gasket ?
                        and the wrist pin is stuck in the piston too,
                        so that maybe gives a more clear sign of whats happened
                        • E
                          E
                          erion1
                          here is a vid of the cylinder
                          https://imgur.com/gallery/HFiRhOS
                          • E erion1
                            @erion1
                            Like I said, the cost difference between a rebore and a hone is not worth pinching pennies over! A heat seizure has smeared the two metals together…
                            Also not all motorcycle engineers are the same. I’ve seen some shocking shit done by firms. If you are in the UK go to PJME for the work, not a ‘mom & pops’ corner place. The piston should of been matched to the rebore, without any movement or ‘ticking’. I’ve had places give me the same kind of fit. I only go with known, reputable places now…
                            New gaskets every time!…
                              Oh dear, you should not be reusing the head gasket, or any gasket really.
                              Sounds like to me, the head gasket has not sealed, it has drank all the coolant and the engine has heat seized. That bore looks pretty scuffed and at minimum is going to want a hone, but as @SpookDog says, looking more likely like a rebore.
                              Did you not have the temperature sender fitted when you were riding it? That should have gone into the head. Go into the radiator and stick your fingers into the top, I'd expect that to be full of two stroke oil by now so should be all slippery. Either way, you're going to need to flush the cooling system with some cleaning agent to remove all the two stroke residue, else the cooling system won't operate effectively, I'd imagine it's warmer where you are and therefore having efficient cooling is even more important.
                                E
                                E
                                erion1
                                @Calum yes the temperature indicator or sensor was fited but the bike never got too hot, i never saw the temperature go above average
                                  @erion1 Hmmm. something is not right there, definitely looks like a heat seizure to me, you see how it's scuffed on both sides, this indicates the piston expanded more than the cylinder walls. This can be down to one of two things, insufficient cooling, or too much load on the engine before it was up to temperature.
                                    E
                                    E
                                    erion1
                                    @Calum its confusing bc even on the piston i cant feel the scuffs either on the cylinder even a needle doesnt catch them
                                    • E erion1
                                      @erion1
                                      Bud! I’m guessing that the ‘scratch marks’ are spaced around the piston in 4 places?
                                      This is because you reused a head gasket (worst 15 £-€ you never spent!) It’s called a 4 point heat seizure. If you look up inside of the piston, the inside of the crown will be black and scorched from the heat seizure. Whether you saw it on the temp gauge or not; it overheated…
                                      Other thing is the piston shouldn’t ‘click’ back and forwards if it’s the right size. Neither should you have that amount of blow by past the rings! I think that the person who did your rebore may of done you wrong…
                                      I’ve used old bits to keep me on the road, but never as an end plan! Even then I rode it like a grandad, never above 5-6K max, never like a ‘yoof’…
                                      What country are you in? Somebody might be able to recommend a good motorcycle engineer to help you move forwards…
                                      You’re going to have to put in a proper fitting piston. Why quibble about a rebore?…
                                      If you want to ride and enjoy your bike to the max. Just fix it please!…
                                        @erion1
                                        Sorry if I come across badly, I just want to see the right thing done for the bike, and you! 😉 …
                                          E
                                          E
                                          erion1
                                          @SpookDog haha no wories mate, im planning to get a meteor piston(any thoughts on that?)and a athena gasket a rebore and fit it all together
