  4. Battery eliminator???
9 Posts 4 Posters 3.9k Views 1 Watching
  • dtlukeD
    dtlukeD
    dtluke
    So if i was to buy one of these to remove the battery and shave a bit more weight off the dt would it be a probelem for the power valve? Usually when I turn on the ignition it does a power valve cleaning cycle before I've kick started the bike. What would happen if the CDi/power valve suddenly got the power as the engine started? eBay: http://pages.ebay.com/link/?nav=item.view&id=272360096529&alt=web
      Hhmm good question.
      Says it works fine on rd and they use YPVS.
      All I know is that the powervalve is known to be sketchy on low battery.
      But this ad seems to be fine with it. Wouldn't be any good om the RE since it wouldn't power the startermotor
      • DartyD
        DartyD
        wrote on last edited by Darty
        I ran this Capacitor for a long time using the standard CDI and had no problems with the YPVS servo motor. Yes without charge it won't activate the cleaning cycle from Ignition.
        These capacitors don't hold much charge, and I encountered program/eratic sparking, Miss firing issues using a Programmable CDI without a constant 12V feed.
        dtlukeD 1 Reply Last reply
        3
        • DartyD Darty
          dtlukeD
          dtlukeD
          dtluke
          @Darty so are you saying standard cdi(which i have) it should be fine/ Programmable CDi it could be an issue?
          DartyD 1 Reply Last reply
          • dtlukeD dtluke
            DartyD
            DartyD
            @dtluke Yea. Works fine with the Standard CDI.
            • Y
              Y
              yammad
              Very interested in this,that's a good chunk of weight saving
              • DartyD Darty
                dtlukeD
                dtlukeD
                dtluke
                @Darty thanks - I've ordered one 🙂
                • Y
                  Y
                  yammad
                  Niiiiiice let us know how u find it yh,what year bike are you putting it on?
                  • Y yammad
                    dtlukeD
                    dtlukeD
                    dtluke
                    @yammad will do, 2005
