  4. Motorcycle coolant.
Motorcycle coolant.
6 Posts 5 Posters 2.5k Views
  • dtlukeD Offline
    dtlukeD Offline
    dtluke
    I want some decent coolant in my dt after its rebuild today and have found some unopened motorcycle castrol coolant in my garage. But it says - ' do not use will magnesium alloy engines'. The DT isn't magnesium alloy is it?
      Aluminium. Magnesium would be pretty special lol
      • dtlukeD dtluke
        NINJAN Offline
        NINJAN Offline
        @dtluke Silkolene has got ya covered, but it's only for pro's. 😉
        http://www.ebay.co.uk/itm/361131688882?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        • dtlukeD Offline
          dtlukeD Offline
          dtluke
          Thanks. So it will be fine. Will by that one next time. Cheers for the link
          • Irongamer727I Offline
            I'm running tap water with glycol in my bikes. Should I go through the hassle and replace with "clean water"?
            V 1 Reply Last reply
            • Irongamer727I Irongamer727
              V Offline
              V Offline
              vishanj
              @irongamer727 well, tap water has minerals in it which will be deposited inside the coolant jackets as time goes. This can affect the cooling. Also iron parts may catch rust as well. You may have to flush your cooling system more frequently compared to using distilled water.
