pinning power valve parts needed
You should have this 1 -
You could always just stick a big washer behind the bolt that runs through the middle you can lock it off that way which is what I have ended up doing today as since having port work and the power valve modded it kept moving a little over fully open
@andrewj1680 said in pinning power valve parts needed:
I ve bought the servo kit I can use the standard parts to pin it now
or if I can get the servo to fit my frame I will use it
(the dt engine is in a different frame ) its gonna be a mission to get the servo to fit I wanted to mount it under the tank but the cables are too short
not sure it will be worth the hassle
