  4. DTR Build Up
DTR Build Up
91 Posts 9 Posters 95.0k Views 3 Watching
  • C ConnorDTR
    @Calum Not sure how i'd get the brakes to bed in before the MOT, don't want it failing because of shoddy brakes. In the video near the end you can see how long it took for me to stop, that was giving it everything it's got. Must've only been doing 20.
    I agree that the brakes are shoddy, not a match compared to the twin pistons my cbr125 had! And way worse than my car.
    Think i've found the first upgrade!
    @ConnorDTR decent set of pads and brake fluid. I have had it bad before. How bad I can't say.
    • DartyD Offline
      DartyD Offline
      Standard DTR brakes are a bit rubbish. You realise how old they are more and more. Defiantly get some Braided brake lines front and back, adds the feel you need over the standard hoses. Did you Vacuum bleed the brakes by the way?
      Braking from 80mph on a DT sometimes feels like I need to stick my leg out as an airbrake, GP style... FUN. haha Not confidence inspiring.
      My brakes were okay at best, EBC pads and discs were quite good.
      Sounds nice and perky man! good to see it running well
      • C Offline
        C Offline
        ConnorDTR
        Guess who's bike is going to see the inside of an mot garage for the first time in 6 years!
        • C ConnorDTR
          @ConnorDTR Won't be mine MOT is for squares...jokes. Good luck when is it due.
          C 1 Reply Last reply
            C Offline
            C Offline
            ConnorDTR
            @Calum Well the MOT was due 8 September 2011 lol. But it's going in at 9 tomorrow morning
            • C Offline
              C Offline
              ConnorDTR
              Guess who's suffered from using a cheap headgasket.... This mug
              • L Offline
                L Offline
                LJK_hunter
                wrote on last edited by LJK_hunter
                #47
                How long did it last? because i've recently replaced the head gasket on mine with a cheap one.
                • C ConnorDTR
                  You really should have known better!
                  Athena or Genuine, ever!
                  • L LJK_hunter
                    C Offline
                    C Offline
                    ConnorDTR
                    @LJK_hunter 60 miles...
                      C Offline
                      C Offline
                      ConnorDTR
                      @Calum I really should have, bikes going to be off the road now for a week or so. Ruined my fresh new top end. Also think the head could be warped so going to take it all into college and test it. Well i have a new athena top end gasket set on its way and have a spare cylinder that just needs a quick hone which should last until the end of the month where i can afford a proper rebore
                      • C Offline
                        C Offline
                        ConnorDTR
                        Also i'm going to invest in a digital coolant temp gauge seeing as the koso clocks don't have a temp gauge
                        • C ConnorDTR
                          I have written a guide to skim the head on here mate. You won't need a professional skim unless you reallh have cooked it!
                          Be alright mate they're fairly resilient. But you now you know.
                            C Offline
                            C Offline
                            ConnorDTR
                            @Calum That's where i found the other info i posted up lol, just need to wait for my dad to go out so i can steal the bathroom mirror! Hoping it'll be good for a bit, was so fun riding the bike! Also offroad is hard, i'll post a proper update in an hour or so
                            • C Offline
                              C Offline
                              ConnorDTR
                              wrote on last edited by ConnorDTR
                              #54
                              Well here's how my first day riding my bike went,
                              http://i.imgur.com/WSsEKxc.jpg?1
                              Just a little pre mot prep, checking bearings are tight all lights are working etc
                              http://i.imgur.com/EPdAqV3.jpg?1
                              Admiring my creation
                              http://i.imgur.com/e9wIrrS.jpg?2
                              Passed with no advisories
                              http://i.imgur.com/UomhNDp.jpg?1
                              Went for a good ride with my friend Darryl, we checked out a few trails and i dropped my bike for the first time
                              http://i.imgur.com/2Rvbv2c.jpg?1
                              Went out later in the night to meet my friend from college and his mate as they fancy a DT too! However as soon as i got there the bike cut out, would kick over fine but wouldn't kick in. Tried bump starting it but still no avail, until the loudest bang every could be heard from my bike. This was when i suspected something was seriously wrong, as when you kicked it over there was a new, very questionable noise so i suspected my bottom end has gone.
                              http://i.imgur.com/NoMC7gZ.jpg?1
                              http://i.imgur.com/Zy06OBM.jpg?1
                              http://i.imgur.com/Qs0ch8l.jpg?1
                              When i got home (Thanks to my friend Dan for getting me in his van) I decided to get right down to it and strip the cylinder off in the freezing cold in my shed, Can see what i believe is called a four point seizure, to do with the piston heating up and expanding quicker than the cylinder so the piston gets stuck in the cylinder. When i drained the coolant i saw there was bugger all in there, 100ml at best and it wasn't the same colour as when it went in.... plus the coolant expansion tank has shot out its cap.
                              So i've ordered an athena top end gasket set and going to reuse the old cylinder with a quick rehone and the old piston as there are no marks at all, skim the head using Callums glass and wet and dry method, refill the coolant and hope that she runs again. Going to keep an eye for any white smoke and the expansion tank this time
                              • C ConnorDTR
                                @ConnorDTR that's the one mate. Flat surface as possible. Nice ciruclar motion.
                                Believe me, if you have read my.build thread then you know it can sort out a battered 21 year old engine that had clearly been run with the head gasket gone for a long time lol.
                                  C Offline
                                  C Offline
                                  ConnorDTR
                                  @Calum What grit did you use? Pretty sure i've got some fine emery cloth here aswell, or is that still too rough? I've got 2000 grit but it's those crap little rolls that are about 10 cm wide from halfrauds
                                    Oh dear! Yes I see what's happened here. That barrel could get away without a hone to ne fair. But you're the right thing.
                                    I was running my dt with too much fuel and it bore washed and scored similar. But wasn't the end of the world. Still runs.
                                    • C ConnorDTR
                                      @ConnorDTR pretty sure it was 120, 240 &460
                                        C Offline
                                        C Offline
                                        ConnorDTR
                                        @Calum That's the cylinder i'm going to save for a proper hone or if need be a rebore, also not going to use the same place as last time, £140, supplied me with cheap gasket set and a mitaka piston and it took 2 months... Think the reason it didn't run was because all the compression was leaking past the head gasket then. And that's pretty low, quiet a rough grit then? I have some 400 grit from doing my wheels, i'll give it a go tomorrow cheers
                                        • C ConnorDTR
                                          @ConnorDTR a rebore is 30. Forged piston is 60 and a genuine head gasket is 20. Done deal. I get mine done at Yamaha.
