  3. Suspension
  4. Fork seals
Fork seals
31 Posts 7 Posters 11.3k Views 1 Watching
  • RickyR Offline
    RickyR Offline
    Ricky
    Hi guys not posted in a while I need some advice on changing my fork seals on my 2005 dtx I've looked on YouTube but there isn't any videos with my forks any advice or link to a video would be much appreciated thanks
    DT 125X
      You might not find any for a DTX, but any conventional fork seals are going to be very similar in nature. Not much to them to be honest very simple job to change.
      RickyR 1 Reply Last reply
        RickyR Offline
        RickyR Offline
        Ricky
        @Calum can you give me some advice on changing them thanks
        DT 125X
          Advice I'd give.
          It's a simple job, but you want a nice clear work bench and do one at the time.
          If you're doing it yourself you will save yourself some dough. That saved money could be invested in some progressive springs and thicker oil to stiffen up the front end. Much more desirable on an SM 😄
            Advice I'd give.
            RickyR Offline
            RickyR Offline
            Ricky
            @Calum I was looking at these http://m.ebay.co.uk/itm/390929639656
            DT 125X
            • RickyR Ricky
              @Ricky I like the fork oil, good choice. No idea about the seals.
              Could be amazing, could be terrible.
              For confidence go OEM.
              If you're happy to do the job twice, grab those and see how you get on.
              A chap on here had a garage do it, I suspect they didn't use OEM and it's now weeping. So....
              • F Offline
                F Offline
                I fitted pyramid parts headstock bearings, they seemed good quality from what I could tell. Probably one of the better non-oem parts manufacturers
                • J Offline
                  J Offline
                  jgr72
                  I have ordered new fork seals from ebay, and I have 15W fork oil waiting... Now front end feels like there's only springs left 😄 Stock oil is 10W but 15W should be little stiffer.
                    You can get progressive springs that look really fancy. If I didn't go down the USD route then I would have done this myself.
                    • F Offline
                      F Offline
                      I actually need to do my fork seals. Clocked the progressive springs on eBay as well but unsure how good they'd be in a DTX. They're only listed for the DTR
                      • F finnerz89
                        @finnerz89 what are progressive springs just stiffer?
                          @declan Progressive springs are springs that get stiffer as they progress down towards bottoming out. The stock springs can just bottom out quite easily.
                          Thicker oil will be used to make it stiffer, the progressive springs just help with the dampening.
                            @Calum my front forks must be modified as they're pretty stiff
                            • J Offline
                              J Offline
                              Jens Eskildsen
                              You need to add stiffer springs if youre bottoming out, using thicker oil just masks the real problem.
                              Thicker oil slows the damping, which then gives the springs more time to work. Often resulting in the fork not working through the complete stroke, so you use less of the suspension available. Thats fine for street riding, where the brake-dive is reduced, and theres plenty of suspensiontravel compared to streetbikes.
                              I've always felt that thicker oil makes the ride harsh, in lack of better words. So I use lighter oil (5w-7,5w on theese types of forks.)
                              At my peak, I was above 110kg in riding-gear, and the bike still didnt bottom out on my stock bike. Make the front end lighter when riding over holes, by using throttle and moving your weight around. Learn how to use small bumps in the terrain as kickers, to get the front end up and over obstacles, wheather it beeing small potholes, or big rocks, logs ect.
                              Stiffer springs and heavier weight oil wont compensate for drivingskills, no offence ment.
                              • J Jens Eskildsen
                                @Jens-Eskildsen I didn't have any issues on my DTRE, but my mates DTR was like a pogo stick. Great fun but definitely would have benefitted from stiffer suspension.
                                USD's I run are just surreal. Massive difference. My riding would be complete noob as I just commuted. So sitying comfortably etc.
                                • J Offline
                                  J Offline
                                  Jens Eskildsen
                                  I think his shock was in a bad state, perhaps its lost some of the oil or gas, thus lacking much of the damping. Or it could just be old and worn out. A new stock one would probably be a big upgrade. Setting the sag should tell if the shock is bad or not.
                                  • Irongamer727I Offline
                                    What would you go for in terms of seals and oil if the forks are abused by wheelies often?
                                    Thicker oil?
                                      Would you buy OEM seals and buy oil separately?
                                      • Irongamer727I Irongamer727
                                        @irongamer727 I went for Athena oil seals on my RS.
                                        Really you want to ensure that none of the bushes are excessively worn.
                                          @calum What bushes?
                                          F 1 Reply Last reply
