  4. Front brake light switch wiring
8 Posts 3 Posters 2.2k Views
  • D
    dan28
    There should be a brown wire that goes to the front brake light switch
    ( is this correct ? )
    I be tidy up my loom an don't seem to have the wire an more does this wire come off one of the other wires that go to warning lamps I can't see any were else to take the feed from
      What year is the bike mate.
      Thew newer models have revised wiring. I don't know if the colours are all the same.
      D 1 Reply Last reply
        dan28
        @calum
        It's 1989 mate
        • D dan28
          @calum
          It's 1989 mate
          @dan28 I'll have a look at the wiring diagram tonight, if no one else chimes in.
          • F
            F
            Brown wire is a switched feed from the ignition. You can take it from anywhere.
            See attached pic, I'm not sure what model code your bike is but all the DT diagrams I have, have the same wiring.
            • F
              F
              Item 35 is the front brake switch, item 1 is the horn and 24 is the ignition switch.
              • F finnerz89
                dan28
                @finnerz89
                Thank you
                So I could run a wire from the brown that goes to oil warning light ?
                We're does the brown wire come from that runs to brake light switch
                • F
                  F
                  According to the handy diagram I posted for you, the horn lol
