  3. Framework
  4. Quick help for suspension service
36 Posts 4 Posters 9.7k Views
    @finnerz89 Nah not in that part. It's the part that sandwiches between the frame that has the needle bearings. It's just a collar on the bronze bush for the bit declan is working with.
    #25
    @calum so the bearing are up at the engine side I wanted to get em out but the bolt is too hard to get to it moves smoothly enough though so I think it’s fine
      @declan Yeah mate. All I can say is good luck lmao.
      They poooorroopperly seize in their.
      The trick is to soak that part for at least a good 24 hours.
      And then on reassembly, grease the balls off it.
      That part always seizes as there is not grease nipple IIRC.
      But yeah that's a good one to replace as it's going to exhibit the most stress.
        @calum hopefully I can get to it in the future but atleast the collars that were borderline seized will be good for a while it’s almost like they don’t want you to get to it so then you need to buy expensive bearings and in some cases pay Yamaha to do it I think I’m on to something 😏
          @declan Nah, the main ones have grease nipples on. Blame poor owners who don't bother looking after them.
          Ultimately it's likely they've never been removed, or properly serviced, it's a miracle they've survived that long.
            @calum yeah it’s a real shame it’s not been looked after leaves me picking up the slack
              @declan Trust me, the bike will be that much better once you've put the effort in.
              declanD 2 Replies Last reply
                @calum I already have it’s just been so neglected painted swing arm I painted the frame and other stuff yesterday it’s lookinh better and better
                  @calum is there supposed to be rubber seals either side of the bushing for behind the dog bones?
                    @declan yes.
                      @declan yes.
                      @calum ffs
                        @calum ffs
                        @declan Have you lost your rubber rings??? LOL 😉
                          @ninja shhhhhh
