  3. Pv adjustment help
Pv adjustment help
42 Posts 6 Posters 11.2k Views
    @declan Nah, it should be flush with the port bud.
    @calum it’s lined up nicely now mate
      @declan Cool, so with that being the case, if it's still not reving past 8K, you now at least now it's not the PV. To test that properly. Let the PV line with the port, then disconnect the servo. It should red line unless there is another underlying issue.
        @calum okay Calum thanks again bud
        • SpannersS
          SpannersS
          Spanners
          Hi All........
          Remember when l first joined the forum and said there would be some stupid questions.
          As you all know l have been making good my DT 125 and today l actually was able to take her for a spin.
          Now l have no doubt that the PV is doing something but when it come in it feels like you are clutching it?
          It is wild, at 6000rpm all hell breaks loose, but it just feels like it is not operating properly.
          I hope l explain it properly, it’s not a rush of power more like your dipping the clutch to create more RPM’s?
          Any ideas, is it too a set up issue?
          Sounds stupid but how should it feel? 🤣
          • F
            @Spanners Are you sure your clutch isn't just slipping?
            SpannersS 1 Reply Last reply
            • SpannersS Spanners
              Hi All........
              @spanners Sounds like either the chain, or the clutch is slipping.
              I had a mate with a 2001 DTR said the same thing to me, didn't realise the chain was spinning on the front cog believe it or not. I took it for one spin up the road and was like F me mate that is deadly. If it slips and coils up Bye Bye engine as the chain smashes the crank case together.
              If you've put Castrol Magnetec oil in the gearbox, the clutch will slip.
                SpannersS
                SpannersS
                Spanners
                @calum
                Thank you again for all your help!
                The clutch plates changed when l had the water coming in the gearbox from the water pump seal, could be a bedding in issue?
                Both sprockets and chain brand new, changed as a full kit.
                Oil in gearbox is Rock oil lite, bought from Wemoto, someone suggested on a forum and definitely not magnatec!
                  SpannersS
                  SpannersS
                  Spanners
                  @finnerz89
                  I can’t be fully confident, but are brand new clutch plates.
                  Could it be a bedding in issue?
                    @finnerz89
                    @spanners Did you soak the clutch plates in oil 24 hours prior to installing?
                      @finnerz89
                      @spanners are you sure your pv is set up mine was like a rev limiter on and off power around 6.5k
                        SpannersS
                        SpannersS
                        Spanners
                        @calum
                        We cover the clutch plates in the gearbox oil before installing them.
                        It was in accordance with the Haynes manual.
                        Should they have been soaked 24 hours?
                        If so, what are the implications of not doing this?
                        Have they not been soaking in the gearbox oil since installation?
                        How do l stop the clutch slipping from now or when it wears will it natural gather more grip when the high spots wear?
                        If not I’ve got a dangerous reving rocket! Ho-ho!
                        F declanD 2 Replies Last reply
                          @calum
                          @spanners have you adjusted the lever properly as per the manual? Could just be that it's set up wrong
                            @calum
                            @spanners no it must be 24 hrs the implications are you will burn up your friction material they won’t soak as the oil goes to the sump and does not sit in the clutch cover
                              SpannersS
                              SpannersS
                              Spanners
                              @declan
                              Oh bugger!
                                SpannersS
                                SpannersS
                                Spanners
                                @finnerz89
                                The bike apparently had a top end rebuild before l got it so l have not messed with anything to do with that. I will have a read and investigate tomorrow.
                                Thank you for your help!
                                F 1 Reply Last reply
                                  @finnerz89
                                  @spanners you should have about 3mm of free play at the lever as a rough figure
                                    Could be the clutch springs not torqued up properly.
                                      SpannersS
                                      SpannersS
                                      Spanners
                                      @calum
                                      I bought a full clutch kit we replaced everything.
                                      All springs are new and we adjusted it to the best of our knowledge and skill.
                                      Maybe the problem was with the repairers! Ha-ha!
                                      Clutch seems pretty solid apart from the power valve, you would have thought if it was slipping, it would do it through all the gears?
                                      I’ll get it up to full speed in 5th to see if it slips, then back to the old drawing board...... 😪
                                        It's frustrating innit! Just as you think the end is near something else crops up! Good luck and hope you find the problem quickly,
                                          @calum
                                          @spanners it's more likely to do it in the higher gears.
                                          I'd follow the Haynes manual procedure for setting up the clutch, then worry about the power valve after.
