  4. Clutch spring bolt size??
11 Posts 4 Posters 1.9k Views
  • M Offline
    M Offline
    Mitch_350z
    Hi all, like a total idiot I've over tightened a clutch spring bolt. Just need to know the thread size of the bolts as I've seen a few different sizes/lengths when looking for some new ones?? I've seen m5 and m6 at different lengths so not 100% sure.
    Thanks in advance.
    ricky0115R 1 Reply Last reply
    • M Mitch_350z
      Thanks in advance.
      ricky0115R Offline
      ricky0115R Offline
      ricky0115
      wrote on last edited by ricky0115
      @mitch_350z my 98 DTR is M6 x 20mm
      M 1 Reply Last reply
      • ricky0115R ricky0115
        M Offline
        M Offline
        Mitch_350z
        @ricky0115 would that be the same as a 2002 model??
        • M Mitch_350z
          ricky0115R Offline
          ricky0115R Offline
          ricky0115
          @mitch_350z I know it’s the same as 04 DTRE
            M Offline
            M Offline
            Mitch_350z
            @ricky0115 alright mate thanks, do you know what size head the bolts are as I haven't got them to hand and can't remember of the top of my head
            • M Mitch_350z
              ricky0115R Offline
              ricky0115R Offline
              ricky0115
              @mitch_350z 10mm or 1/4”
              M F 2 Replies Last reply
                M Offline
                M Offline
                Mitch_350z
                @ricky0115 alright, thanks for the info
                  F Offline
                  F Offline
                  @ricky0115 do you mean 3/8”?
                    Head bolts?
                    Or nuts. Since you shouldn't be using bolts on the head.
                    M10 Head Nuts IIRC.
                      Head bolts?
                      M10 Head Nuts IIRC.
                      M Offline
                      M Offline
                      Mitch_350z
                      @calum I meant the head of the bolt for the clutch bolt springs
                      • M Mitch_350z
                        @mitch_350z Right, yeah 10mm IIRC. I replaced all mine with M6 Stainless Steel Hex heads.
