Bulb compatibility
@ricky0115 Yeah, which is why I say the lighting out f them will br poo.
Bought this Apico headlight
Itās not very bright & it doesnāt have hi/lo beam.
Is it possible to swap the bulbs for some Brighter ones with hi/lo beam?
@ricky0115 Are they LED bulbs or regular? Are you able o remove them and see a type code ???
@ninja they are halogen, I will take a look tomorrow but I was looking on eBay at some H4 bulbs, just waiting on measurements.
@ricky0115 H4 will give you a brighter light for-sure. it all depends on the fitment and what will suit that.
DTRE Lights are probably going to be the best in terms of brightness. They are so much better than the DTR ones, and the enduro ones are really more for style over substance.
Again, you actually don't need lights for a legitimate MOT. But if they are fitted, then they must comply.
What we do is simply place a piece of card over the bulbs, and tape up the switches.
You can get a day time MOT with that done.
With your input, this post could be even better š
