  4. Powervalve dtr 2002
Powervalve dtr 2002
15 Posts 3 Posters 1.6k Views
  • C Offline
    C Offline
    cartermarc1
    My powervalve doesn’t seem to work properly I recent replace the the servo put new one on I think got the cables on right when put the battery on it turns one way doesn’t return has now bottom power I’ve set the it up with the cables so it lines up with the hole if u put battery on it goes clockwise and stays there can hear the servo trying to move but won’t moves freely with hand any help much apriciated thanks
    • C cartermarc1
      @cartermarc1 sure your cables aren’t too tight?
      C 2 Replies Last reply
        C Offline
        C Offline
        cartermarc1
        @declan Ile take a picture of them won’t be Wednesday night tho there not tight got no.1 going to no.1 same with no.2 from pics I’ve seen of others looks right thanks
          I had a similar problem when my cdi went faulty. Was an aftermarket CDI mind you.
          C 1 Reply Last reply
            C Offline
            C Offline
            cartermarc1
            @calum ok mate thanks
              C Offline
              C Offline
              cartermarc1
              )I was wondering if I had the cables the Wright way round I’ve read that some are crossed over
              • C cartermarc1
                @cartermarc1 I would disconnect the cables and just make sure the valve does a sweep properly when you switch the ignition on and off.
                  C Offline
                  C Offline
                  cartermarc1
                  @calum I’ve took the cables off it’s working anti-clockwise on the servo but only when I turn it clockwise with my hand
                  • C cartermarc1
                    @cartermarc1 It doesn't do a cleaning cycle then? Only going one way and not returning.
                    Sounds like the servo ECU is burnt out.
                    • C Offline
                      C Offline
                      cartermarc1
                      No mate its not only turning one way have a look for a new servo how do I open it fully while I find one thanks for the help
                      • C cartermarc1
                        @cartermarc1 I don't suspect it's the servo.
                        When I had this issue, it was the CDI that was faulty (since the servo's operation is controlled by the CDI). But depending on your model it might be a separate ECU.
                        For a 2002, I believe it's the CDI.
                        I would just leave it disconnected, and pin the valve open for now.
                        • C Offline
                          C Offline
                          cartermarc1
                          How do I pin the valve thanks
                          • C cartermarc1
                            @cartermarc1 Set it to open and lock off the nut to stop it rotating.
                              C Offline
                              C Offline
                              cartermarc1
                              @calum to set it to open is powervalve is flush with the top ? Thanks for all your help
                              • C cartermarc1
                                @cartermarc1 The valve will be flush with the exhaust port, since the valves job is to altr the exhaust port height to enable better low end performance by restricting lost fuel and air theough the open port.
