  4. Powervalve dtr 2002
Powervalve dtr 2002
15 Posts 3 Posters 2.6k Views 1 Watching
    I had a similar problem when my cdi went faulty. Was an aftermarket CDI mind you.
    C 1 Reply Last reply
      C
      C
      cartermarc1
      @calum ok mate thanks
        @cartermarc1 sure your cables aren’t too tight?
        C
        C
        cartermarc1
        )I was wondering if I had the cables the Wright way round I’ve read that some are crossed over
        • C cartermarc1
          @cartermarc1 I would disconnect the cables and just make sure the valve does a sweep properly when you switch the ignition on and off.
            C
            C
            cartermarc1
            @calum I’ve took the cables off it’s working anti-clockwise on the servo but only when I turn it clockwise with my hand
            • C cartermarc1
              @cartermarc1 It doesn't do a cleaning cycle then? Only going one way and not returning.
              Sounds like the servo ECU is burnt out.
              • C
                C
                cartermarc1
                No mate its not only turning one way have a look for a new servo how do I open it fully while I find one thanks for the help
                • C cartermarc1
                  @cartermarc1 I don't suspect it's the servo.
                  When I had this issue, it was the CDI that was faulty (since the servo's operation is controlled by the CDI). But depending on your model it might be a separate ECU.
                  For a 2002, I believe it's the CDI.
                  I would just leave it disconnected, and pin the valve open for now.
                  • C
                    C
                    cartermarc1
                    How do I pin the valve thanks
                    • C cartermarc1
                      @cartermarc1 Set it to open and lock off the nut to stop it rotating.
                        C
                        C
                        cartermarc1
                        @calum to set it to open is powervalve is flush with the top ? Thanks for all your help
                        • C cartermarc1
                          @cartermarc1 The valve will be flush with the exhaust port, since the valves job is to altr the exhaust port height to enable better low end performance by restricting lost fuel and air theough the open port.
