Dtr125 CDI/Powervalve issue
This is exactly what mine did and it turned out to be the CDI but on the wires that recieved voltage it was a really low amount for less than a second to make it twitch, I was lucky and found one for £25 on ebay, you can also try searching for CDI from the Derbi GPR125 2T as im pretty sure its the same.
There's one in France for slightly cheaper than you have found.
@LJK_hunter thanks very much for your reply. That's exactly what mine does. I will get a new CDi and take a risk on the derbi one. Cheers again for your help
@LJK_hunter thanks again for your advice and the eBay link. Ordered the cdi - it arrived a few days later from France and problem completely fixed. First time the powervlave has worked since owning the bike and WHAT A DIFFERENCE!!! so much nicer to ride.
So, I seem to have a similar problem. The servo worked about a month ago(just tested it) but now once I wanted to hook up the pv and try it, the servo is bearly moving.. it can do one turn but wont "return". Ideas?
A freaking cog inside the servo had broken at one spot! Really Dt? Really?
I can't find parts for the inside of the servo..
@irongamer727 most likely will be an entire servo
@declan if I can't get it 3D built.
@irongamer727 I was thinking that
What is it, Gilera SC125 runs a DTRE engine as well. Although a quick look shows they're quite expensive lol
@calum any ideas on what I could do?
@irongamer727 Buy another servo unit. Plenty around on the net. Sure I saw that they were being produced in Germany new for around £60.
Or just pin the valve open.
@calum interesting. Could you link the website?
@irongamer727 Couldn't find it. I did look sorry. It might be on here. Try searching.
