  4. Dtr125 CDI/Powervalve issue
15 Posts 5 Posters 5.3k Views 1 Watching
  • LJK_hunterL LJK_hunter
    This is exactly what mine did and it turned out to be the CDI but on the wires that recieved voltage it was a really low amount for less than a second to make it twitch, I was lucky and found one for £25 on ebay, you can also try searching for CDI from the Derbi GPR125 2T as im pretty sure its the same.
    There's one in France for slightly cheaper than you have found.
    http://www.ebay.co.uk/itm/DERBI-125-GPR-RACING-BOITIER-ALLUMAGE-CDI-2004-2008-/172221604252?hash=item281935219c:g:SmMAAOSwagdXSKlk
    dtlukeD
    dtlukeD
    dtluke
    @LJK_hunter thanks again for your advice and the eBay link. Ordered the cdi - it arrived a few days later from France and problem completely fixed. First time the powervlave has worked since owning the bike and WHAT A DIFFERENCE!!! so much nicer to ride.
    • Irongamer727I
      So, I seem to have a similar problem. The servo worked about a month ago(just tested it) but now once I wanted to hook up the pv and try it, the servo is bearly moving.. it can do one turn but wont "return". Ideas?
      • Irongamer727I
        A freaking cog inside the servo had broken at one spot! Really Dt? Really?
        • Irongamer727I
          I can't find parts for the inside of the servo..
            @irongamer727 most likely will be an entire servo
              @declan if I can't get it 3D built.
                @irongamer727 I was thinking that
                  What is it, Gilera SC125 runs a DTRE engine as well. Although a quick look shows they're quite expensive lol
                  @calum any ideas on what I could do?
                    @irongamer727 Buy another servo unit. Plenty around on the net. Sure I saw that they were being produced in Germany new for around £60.
                    Or just pin the valve open.
                      @calum interesting. Could you link the website?
                        @irongamer727 Couldn't find it. I did look sorry. It might be on here. Try searching.
