  4. 1989 rebuild update
1989 rebuild update
127 Posts 14 Posters 81.4k Views 2 Watching
    Stripped the front brake caliper, in poor condition, dust seal filled with brake fluid and piston fitted back to front, you can see a bit of the piston seal in the dust seal groove. Sure the damage was done when the piston was fitted by whoever. Chucked the lot in the ultrasonic cleaner before I touch it, cleaner need fresh fluid anyway.0_1513284449187_20171214_201327-1224x1632.jpg 0_1513284468055_20171214_201334-1224x1632.jpg 0_1513284489831_20171214_201343-1224x1632.jpg 0_1513284506861_20171214_201352-1224x1632.jpg
      This is the caliper after ultrasonic clean.
      0_1513291995813_20171214_224839-1224x1632.jpg 0_1513292017354_20171214_224852-1224x1632.jpg
        Calipers painted and rebuilt, fitted loose to bike, waiting for rear master cylinder hose to and front cable clip to arrive. Refitted carb with 240 main jet, again waiting for engine water hoses to arrive so I can fill and try starting engine (😨), speedo cable fitted and swingarm chain protector/upper roller fitted. Not too much to do now, wheels not back from Central yet and Galfer disc unlikely to arrive until new year.
        0_1513549593410_20171217_142416-1024x576.jpg 0_1513549605072_20171217_143425-576x1024.jpg
          Have had to endure Christmas crap all week, but SANTA did deliver the Galfer brake disc, and as I am on the nice list allowed time to secluded myself in the garage today with bikes and music. Downside is new hoses for RAD never arrived so had to reorder, sticking the old ones back on for now.0_1514109097462_20171224_094041-1024x576.jpg
          • O oldman
            @oldman I went with Galfer for my disc. Nice one!
              Looks good quality, not much more than standard replacement, mates choice (a good one) filled with oil and water after fitting hoses, all bled and started 3rd kick, sounds good. Exhaust can really tight fit onto expansion chamber so mounting holes not lining up,will get mini grinder out after Christmas. Spare wheels while waiting for rebuilt ones from Central Wheels, seems they are not quick either!0_1514136266083_20171224_170253-1024x576.jpg
              • V
                V
                vtrn_raptor
                Did you have to remove the old steering lock without a key or wasn't their one their before hand
                  There was not one before, already taken out, going to do the 88 though which already has lock fitted , no key,
                  • V
                    V
                    vtrn_raptor
                    I need to get a new one brought the bike and didn't come with the steering lock key are they easy to remove without a key
                    O 1 Reply Last reply
                      I won't know until I do it, will have to get pin out of cover plate that fits in to frame and then drill lock out, should not be too bad (famous last words!)
                      On the bike front waiting for wheels to come back, list of things to do very short now, have run engine right up to temp and sorted exhaust, fitted panels and tank to make sure all ok, need a better seat though, on my to do list.0_1514754557592_20171231_204744-1024x576.jpg
                        Heres a couple of pictures of new parts that show what you have to remove0_1514755607001_20171231_212420-576x1024.jpg 0_1514755621097_20171231_212437-576x1024.jpg
                          This is looking lovely.
                            It's getting there Calum, waiting for wheels seems to be the norm, thought Central would have a quicker turnover, happy new year BTW!
                              Wheels back from Central with stainless spokes (0.5mm thicker) and black satin hubs, look fantastic. My pals putting the tyres on etc, chainset arrived as well so nearly there, will post pics of wheels later this week hopefully, just as well as the spare rear wheel I have on at the moment stinking my garage out. Don't know what it is but wheels sprayed with something smelly! Imageworks sorting decals , new owner picked 1990 model year.
                              Ended up stripping fuel tap as leaking when I put fuel in, ultrasonic clean, new o ring and all done.
                              Also fitted new radiator hoses that arrived saturday.
                              Replacement front brake hose also arrived, HEL kit line was too short when fitted so ordered another 100mm longer and that's fine, anyone else had that problem?
                              • O oldman
                                @oldman No, but I asked for a few extra mm's when I had mine made up.
                                  The R&G ones on the 88 were fine, just the front out of the HEL kit. Thought it might be the Renthals but not that much different, will know for next time though, 1.4m perfect fit, kit one 1.3m. Sure I will find a use for it somewhere.
                                  • O oldman
                                    @oldman the stock washers that come with the hel failed on mine spat fluid everywhere I had to use other ones but the length was perfect the stock washers rust like a bitch too
                                      @declan The washers should most definitely be copper, I.E would never rust. Will oxidise but not Iron Oxide, since it's copper.
                                        All copper washers with kit, never seen a kit with anything other?
                                        • O oldman
                                          @oldman mine were steel
