  4. Autolube pvc see through pipe bubbles
30 Posts 7 Posters 7.3k Views
    @irongamer727 yes using your finger will work but sometime it causes the Rev cable junction to screw up so you have to take your tank off and sort the cables out it happen everytime I do it it even sometimes throws the Rev cable out the carb
    @declan not an issue as the bike is already teared down after top end swap.
      @irongamer727 all good then
        @declan literally took 1 minute to "bleed". Didn't even bother to use the bleed screw. All good now👍 u also running clear hoses?
          @irongamer727 from pump to manifold yeah when I have time I hope to change tank to pump as the hose is old and it’s pretty much plastic it’s that old it will crack if your not careful
            @declan allright, but why? As you already have a clear oil pipe from the pump, I don't see the benefits of having the entire feeder hose transparent?
              @irongamer727 like I said it’s old and brittle if it snags a branch and I don’t realise it will just crack it’s pretty much a ticking time bomb
              • Sgt Robuck 5S
                Sgt Robuck 5S
                Sgt Robuck 5
                Today I was out riding the bike kept cutting out (While at Idle), I realized that the revs were down at idle so i adjusted it; seems to be idling fine now but what was the cause? I did adjust the oil pump after changing the tubes as it was off. Do you guys think that the cause of the lower idle was because of the oil pump adjustment?
                • Sgt Robuck 5S Sgt Robuck 5
                  @sgt-robuck-5 it’s possible yes if you turn the pump by hand too much it will cut the bike out so you probably had a low idle to start off with can you help me out with something? Look on your carb on the right side of it the exhaust side just to the right or the airbox boot there should be a small nipple slightly pointing upwards does it have a pipe on it and if so where does the pipe go thNks.
                      @calum can’t see it in those pictures
                      Sgt Robuck 5S 1 Reply Last reply
                        Sgt Robuck 5S
                        Sgt Robuck 5S
                        Sgt Robuck 5
                        @declan Is this the one? it's right next to the air box and points slightly up
                          @sgt-robuck-5 just a vent hose then?
                          Sgt Robuck 5S Irongamer727I 2 Replies Last reply
                            Sgt Robuck 5S
                            Sgt Robuck 5S
                            Sgt Robuck 5
                            @declan Yeah, is hanging down next to the rear strut (Suspension)
                              @declan same for me, venthose
                                @irongamer727 thanks lads
