  4. What damage have I done?
38 Posts 2 Posters 27.7k Views 1 Watching
  • M
    M
    Matt47
    Ok, so my next silly question is... How do I remove seals the correct way to avoid damaging anything?!
    Think I have read that you can use screws to give yourself something to pull on - is this correct? Not keen on digging them out with a flat-head (unless they pop out easily).
    You can probably tell I'm a bit nervous about the whole thing, guess I need to man up haha! 😛
    • M Matt47
      @Matt47 I always had access to the seals from behind. Aka if they are the main bearing seals then removing the main bearings will give you access to them.
      • M
        M
        Matt47
        Ah, makes sense thanks!
        There was me thinking I had everything on my rebuild list, and I forgot to get the other bearings...
        All remaining bearings seem to be in great shape, but I guess I need to weigh up whether or not to do a full rebuild without all new bearings. Is it worth the risk?!
        • M Matt47
          @Matt47 What bearings need replacing?
          The gearbox bearings cost 20 quid. It would be silly not to sort those out st that price.
          If I were splitting the cases then I would just replace the bearings. But that's me.
          • M
            M
            Matt47
            I only have the 2 main bearings for Crankshaft, and the top end stuff.
            I'll have to commandeer the oven once my wife has gone to bed, and get them all out and have a proper look at them! They all feel/look in good nick but I might as well take them out anyway to make the seals easier to change.
              As said, for their cost I'd do the gearbox bearings.
              • M
                M
                Matt47
                Yeah I suppose so, especially after seeing the post on gearbox bearings (quarter of the price of what I can find in France - and that includes postage from UK).
                Disappointed that I overlooked these when ordering, but it would annoy me more if I didn't do it right after it has sat in bits for 7 months plus!
                Cheers for all your support mate, will hopefully get them ordered up soon.
                  Simplybearings yeah? Grab all th Koyo bearings
                  • M
                    M
                    Matt47
                    Yeah, that's the one - amazing value once you know what to look for! €105 for 2 genuine Crank bearings or €28 for 2 koyo shielded (which were what mine were).
                    • M
                      M
                      Matt47
                      Tonight I heated up the crankcase halves to remove the bearings, and got all out apart from the 2 in the picture.
                      http://i1377.photobucket.com/albums/ah75/MatthewT47/20150124_144844_zpsnakligp9.jpg
                      How do I go about getting these out, as they are only accessible from one side?
                      Cheers, Matt
                      ps. sorry about the date on pic lol,
                      • M Matt47
                        Cheers, Matt
                        @Matt47 i lay the crankcase faced down. With enough heat the bearing simply dropped out into the oven.
                        It was getting it back in which took a bit of skill.
                        • M
                          M
                          Matt47
                          Ok cheers, will try again tonight. Obviously needs more cooking - gave it 30min at gas mark 1.
                          • M
                            M
                            Matt47
                            So I tried again and no joy, then left it in almost an hour and the only thing that happened was I melted stuff unexpectedly... Guess i will have to take it somewhere to get it removed.
                            Meanwhile, does anyone know what this and the other needle rollers are so I can get them ordered from simplybearings?
                            • M Matt47
                              @Matt47 should only need 10 or so minutes...looks like you will need a hydraulic puller. They can be had off eBay for 40 quid. Don't knoe how good those ones are though.
                              • M
                                M
                                Matt47
                                Yeah a blind bearing set would be cool, but a decent one is big bucks - and it's not an everyday job for me! Cheap tools are great if they work but will probably get someone to do it rather than take the risk.
                                I even tried a rawl anchor on a diy sliding hammer and this just broke one of the collet parts off the bolt rather than move the bearing - this thing is stuck solid!
                                Bloody thing is driving me potty!!!
