  4. What damage have I done?
38 Posts 2 Posters 27.7k Views 1 Watching
  • M
    M
    Matt47
    OK cheers. So I guess first step is to take top end into a bike shop and let them sort that out if it needs work done. Then I know what size piston I need (if they don't do it).
    New bolts sounds like a good idea too, hadn't thought of that!
      Yeah, get it to a shop and ask if you will be fine with a hone. In my experience you don't tend to save much money by buying the piston yourself.
      I mean sure, if you can get the piston cheaper then by all means. But the risk of buying the wrong one could outweigh the savings you might make.
      • M
        M
        Matt47
        wrote on last edited by Matt47
        OK so not much progress since last post, but I have now at least removed engine from the frame...
        Still not made it to a shop to check cylinder, but have ordered a flywheel puller and made up a holding tool for clutch/flywheel which I'm chuffed with!
        All prepped and ready to operate after a good clean. B-)
          Nice, keep us posted. Any problems throw up a thread. ☺
          • M
            M
            Matt47
            Well I finally got myself organised and have everything ready for the rebuild 7 months later! :-S
            Crank has been rebuilt (not by me!), barrel/head skimmed, powervalve cleaned, got full seal kit and full Athena gasket kit ready to go... Now I just need to remember where everything goes. :-))
            • M Matt47
              @Matt47 it's fairly straight forward but do shout if you need help.
              • M
                M
                Matt47
                Ok, so my next silly question is... How do I remove seals the correct way to avoid damaging anything?!
                Think I have read that you can use screws to give yourself something to pull on - is this correct? Not keen on digging them out with a flat-head (unless they pop out easily).
                You can probably tell I'm a bit nervous about the whole thing, guess I need to man up haha! 😛
                • M Matt47
                  @Matt47 I always had access to the seals from behind. Aka if they are the main bearing seals then removing the main bearings will give you access to them.
                  • M
                    M
                    Matt47
                    Ah, makes sense thanks!
                    There was me thinking I had everything on my rebuild list, and I forgot to get the other bearings...
                    All remaining bearings seem to be in great shape, but I guess I need to weigh up whether or not to do a full rebuild without all new bearings. Is it worth the risk?!
                    • M Matt47
                      @Matt47 What bearings need replacing?
                      The gearbox bearings cost 20 quid. It would be silly not to sort those out st that price.
                      If I were splitting the cases then I would just replace the bearings. But that's me.
                      • M
                        M
                        Matt47
                        I only have the 2 main bearings for Crankshaft, and the top end stuff.
                        I'll have to commandeer the oven once my wife has gone to bed, and get them all out and have a proper look at them! They all feel/look in good nick but I might as well take them out anyway to make the seals easier to change.
                          As said, for their cost I'd do the gearbox bearings.
                          • M
                            M
                            Matt47
                            Yeah I suppose so, especially after seeing the post on gearbox bearings (quarter of the price of what I can find in France - and that includes postage from UK).
                            Disappointed that I overlooked these when ordering, but it would annoy me more if I didn't do it right after it has sat in bits for 7 months plus!
                            Cheers for all your support mate, will hopefully get them ordered up soon.
                              Simplybearings yeah? Grab all th Koyo bearings
                              • M
                                M
                                Matt47
                                Yeah, that's the one - amazing value once you know what to look for! €105 for 2 genuine Crank bearings or €28 for 2 koyo shielded (which were what mine were).
                                • M
                                  M
                                  Matt47
                                  Tonight I heated up the crankcase halves to remove the bearings, and got all out apart from the 2 in the picture.
                                  http://i1377.photobucket.com/albums/ah75/MatthewT47/20150124_144844_zpsnakligp9.jpg
                                  How do I go about getting these out, as they are only accessible from one side?
                                  Cheers, Matt
                                  ps. sorry about the date on pic lol,
                                  • M Matt47
                                    Cheers, Matt
                                    @Matt47 i lay the crankcase faced down. With enough heat the bearing simply dropped out into the oven.
                                    It was getting it back in which took a bit of skill.
                                    • M
                                      M
                                      Matt47
                                      Ok cheers, will try again tonight. Obviously needs more cooking - gave it 30min at gas mark 1.
                                      • M
                                        M
                                        Matt47
                                        So I tried again and no joy, then left it in almost an hour and the only thing that happened was I melted stuff unexpectedly... Guess i will have to take it somewhere to get it removed.
                                        Meanwhile, does anyone know what this and the other needle rollers are so I can get them ordered from simplybearings?
                                        • M Matt47
                                          @Matt47 should only need 10 or so minutes...looks like you will need a hydraulic puller. They can be had off eBay for 40 quid. Don't knoe how good those ones are though.
