  4. What damage have I done?
38 Posts 2 Posters 26.1k Views 1 Watching
  • M Offline
    M Offline
    Matt47
    Ah, makes sense thanks!
    There was me thinking I had everything on my rebuild list, and I forgot to get the other bearings...
    All remaining bearings seem to be in great shape, but I guess I need to weigh up whether or not to do a full rebuild without all new bearings. Is it worth the risk?!
    • M Matt47
      @Matt47 What bearings need replacing?
      The gearbox bearings cost 20 quid. It would be silly not to sort those out st that price.
      If I were splitting the cases then I would just replace the bearings. But that's me.
      • M Offline
        M Offline
        Matt47
        I only have the 2 main bearings for Crankshaft, and the top end stuff.
        I'll have to commandeer the oven once my wife has gone to bed, and get them all out and have a proper look at them! They all feel/look in good nick but I might as well take them out anyway to make the seals easier to change.
          As said, for their cost I'd do the gearbox bearings.
          • M Offline
            M Offline
            Matt47
            Yeah I suppose so, especially after seeing the post on gearbox bearings (quarter of the price of what I can find in France - and that includes postage from UK).
            Disappointed that I overlooked these when ordering, but it would annoy me more if I didn't do it right after it has sat in bits for 7 months plus!
            Cheers for all your support mate, will hopefully get them ordered up soon.
              Simplybearings yeah? Grab all th Koyo bearings
              • M Offline
                M Offline
                Matt47
                Yeah, that's the one - amazing value once you know what to look for! €105 for 2 genuine Crank bearings or €28 for 2 koyo shielded (which were what mine were).
                • M Offline
                  M Offline
                  Matt47
                  Tonight I heated up the crankcase halves to remove the bearings, and got all out apart from the 2 in the picture.
                  http://i1377.photobucket.com/albums/ah75/MatthewT47/20150124_144844_zpsnakligp9.jpg
                  How do I go about getting these out, as they are only accessible from one side?
                  Cheers, Matt
                  ps. sorry about the date on pic lol,
                  • M Matt47
                    Cheers, Matt
                    @Matt47 i lay the crankcase faced down. With enough heat the bearing simply dropped out into the oven.
                    It was getting it back in which took a bit of skill.
                    • M Offline
                      M Offline
                      Matt47
                      Ok cheers, will try again tonight. Obviously needs more cooking - gave it 30min at gas mark 1.
                      • M Offline
                        M Offline
                        Matt47
                        So I tried again and no joy, then left it in almost an hour and the only thing that happened was I melted stuff unexpectedly... Guess i will have to take it somewhere to get it removed.
                        Meanwhile, does anyone know what this and the other needle rollers are so I can get them ordered from simplybearings?
                        • M Matt47
                          @Matt47 should only need 10 or so minutes...looks like you will need a hydraulic puller. They can be had off eBay for 40 quid. Don't knoe how good those ones are though.
                          • M Offline
                            M Offline
                            Matt47
                            Yeah a blind bearing set would be cool, but a decent one is big bucks - and it's not an everyday job for me! Cheap tools are great if they work but will probably get someone to do it rather than take the risk.
                            I even tried a rawl anchor on a diy sliding hammer and this just broke one of the collet parts off the bolt rather than move the bearing - this thing is stuck solid!
                            Bloody thing is driving me potty!!!
