Electrical problems, help please
@bananper What you talking about?
I've said something probably went open circuit, hence why the fuse blown. It most likely blew the bulb at the same time. Fuses are exactly the best way to protect circuitary.
I'm waiting on you to go and actually have a look to see if the fuse is blown.
I think 20 amps is correct. It might have been 15 come to think of it.
@bananper Cool, but as I say, there'll be an underlying issue you need to figure out else you'll just end up damaging components. Even the CDI.
Based off you're fuzzy description, I'd suspect that a relay has gone open circuit, or more likely the rectifier has packed up.
