  4. Electrical problems, help please
20 Posts 2 Posters 3.2k Views
  • B Bananper
    @calum well so thats what's wrong? But there was 20A fuses on when i took them out and that have been working until now
    @bananper You said you replaced it right? So it probably failed as it took out a bulb when it went open circuit.
    It's merely a suggestion, go and have a look.
    • B
      B
      Bananper
      @Calum What's the right amperage then?
      • B Bananper
        @bananper What you talking about?
        I've said something probably went open circuit, hence why the fuse blown. It most likely blew the bulb at the same time. Fuses are exactly the best way to protect circuitary.
        I'm waiting on you to go and actually have a look to see if the fuse is blown.
        I think 20 amps is correct. It might have been 15 come to think of it.
        B 2 Replies Last reply
          B
          B
          Bananper
          @calum so one of the fuses seems to be blown
            B
            B
            Bananper
            @calum i've looked into the haynes manual and it says that the TZR model has 20A fuses and the DT model has 15A fuses, can this be the cause?
            • B Bananper
              @bananper What? Do you have a TZR?
              If the DT is 15 Amps, and you have a DT, then I'd strongly suggest putting in a 15 amp fuse.
              As I've said already, sounds like you have a dead short that you need to fix.
              B 1 Reply Last reply
                B
                B
                Bananper
                @calum well now i took out the brake bulb, one string is working the other is not. And i think the turn signal relay is blown aswell
                • B Bananper
                  @bananper Cool, but as I say, there'll be an underlying issue you need to figure out else you'll just end up damaging components. Even the CDI.
                  Based off you're fuzzy description, I'd suspect that a relay has gone open circuit, or more likely the rectifier has packed up.
                    B
                    B
                    Bananper
                    @calum How do i test if the rectifier is the problem?
                    • B Bananper
                      @bananper Impedence test.
                        B
                        B
                        Bananper
                        @calum the indicator should make a clicking sound when turned on shouldn't it?
                        • B Bananper
                          @bananper It's not a car.
                            B
                            B
                            Bananper
                            @calum no? But on other bikes it clicks
                              B
                              B
                              Bananper
                              @calum https://youtu.be/qK4GSDT89mM soo heres what's happening with the indicators. I put a wire on instead of the relay so it would keep lighting. It worked perfectly fine on the right side but on the left it didn't work, any ideas?
