  4. Weird electrical problem
11 Posts 4 Posters 1.7k Views
  • B Offline
    B Offline
    Bananper
    • BluestoesonnoseB Offline
      Bluestoesonnose
      Sounds like a regulator issue, is the one on the bike compatible with the engine?
      2002 DT125R
      B 1 Reply Last reply
        B Offline
        B Offline
        Bananper
        @Bluestoesonnose yes, it started to do this when i installed the new engine, i doubt it is the regulator, and that i might have done something wrong.
          I have had similar, but not identical issues, after faffing around with a rebuilt engine. Turned out the ignition switch loom had just completely corroded and was intermittent.
          Trying to resolve this problem is difficult unless you know exactly what causes it. For me, it would work sometimes, ride the bike down the road and the YPVS would fail.
          Once the bike was on, it was running, but the act of moving it unjarred a corroded cable.
          Check to you haven't tugged one of the wires.
          • F Offline
            F Offline
            So you're saying you have no starter relay?
            Which houses the main fuse and supplies power to the rest of the bike? I reckon you need to find that and fit it
              B Offline
              B Offline
              Bananper
              @finnerz89 i mean the thing you plug into the starter relay, i dont know what its called
              F 1 Reply Last reply
              • B Bananper
                F Offline
                F Offline
                @Bananper a plug? 4 connections in it?
                  B Offline
                  B Offline
                  Bananper
                  @finnerz89 yup
                  • F Offline
                    F Offline
                    Well it's connected to the loom so it must be there somewhere lol
                      B Offline
                      B Offline
                      Bananper
                      @finnerz89 https://mtp-racing24.com/media/image/product/16642/lg/starter-relay-solenoid-yamaha.jpg there should be something there right?
                      • F Offline
                        F Offline
                        Yeah definitely should be a plug in there. 1 or 2 cables for the starter solenoid (to spin the starter) and then 1 or 2 for power to the rest of the bike
