  3. Carburetor
  4. What's missing here?
35 Posts 7 Posters 10.6k Views 1 Watching
  • P Pablo13
    It goes through the cleaning cycle ok when I turn the ignition on, but does sound lethargic doing it. so that would be a new servo/motor thats needed? To be fair I've not tested the battery either, so not sure what kind of condition thats in. That could affect it too couldn't it?
    @Pablo13 Yes a battery not pumping out the required volts would surely affect a lot of things.
    • P
      P
      Pablo13
      PV cables are all adjusted, holes line up etc.
      • P Pablo13
        @Pablo13 Yeah but on some CDI's it will retard the valve at certain RPM.
        That engine should rev out hard all the way to the red line.
        The best way to eliminate it not being the powervalve is to align the valve up through the exhaust port, then disconnect the servo. And take it for a test ride. Bottom end should be lost, but past 6K it should pull hard to 12k
        • P
          P
          Pablo13
          wrote on last edited by Pablo13
          So, check the green black wire is grounded and stick a finger in my exhaust is the next port of call?
          Cheers for the help btw guys 😉
          NINJAN CalumC 2 Replies Last reply
          • P Pablo13
            @Pablo13 LOLLZZZZZ Yep that's the top notch technical diagnosing we all love on this forum dude - very simple but highly effective!!!
            Let us know how you get on??? :grinning_face_with_smiling_eyes:
            • P Pablo13
              @Pablo13 That's for RE's the green and black wire.
              Just align the valve flush in the exhaust port and disconnect the servo.
              That will eliminate it being the valve.
              • P
                P
                Pablo13
                Cool. Its a bit dark out there now, but I'll let you al know how I got on soon 🙂
                • P
                  P
                  Pablo13
                  Its not the valve. I took the exhaust off and aligned the valve, unplugged the servo and it was still the same at the top. What should I look at next?
                  • P Pablo13
                    @Pablo13 Cool, you're getting the same issue then?
                    Have you done a plug chop? What's the fueling saying? You running snorkel in or out? How old is the spark plug. Is it the correct plug?
                    How old is the ignition system?
                    Is the air filter clogged up?
                    • P
                      P
                      Pablo13
                      Yeah still going flat in the higher rpms. Maybe the coil is weak. No plug chops yet, but I stuck a new one in a few weeks back ngk 8 i believe. Also along with a new air filter as it just ticked over 24km.....about 15k miles. Snorkel is in. Problem has been there before the service too. Would be nice to get to the bottom of it 🙂
                      • P Pablo13
                        @Pablo13 Cool, fueling bone stock. Bike isn't modified?
                        It might be just a tired engine. Low compression and piston blowby.
                        • P
                          P
                          Pablo13
                          Just an aftermarket exhaust and a 240 main jet I stuck in, that's it. So compression test next?
                          • P Pablo13
                            @Pablo13 What exhaust you running?
                            Most manufactures stipulate sticking with 210 main jet, despite the uprated exhaust.
                            I don't know the figures that constitute acceptable levels for the compression test.
                            I would look at the electrics first.
                            If the engine sounds sweet, then chances are it is.
                            • P
                              P
                              Pablo13
                              Rino Racing or something similar the exhaust is.
                              So check over the coil next?
                              • P Pablo13
                                @Pablo13 Yeah something isn't right. But 93, if it's the original electrics, then I'd swap out the coil, and HT lead for a new one.
                                If it's still causing issues then it can only be the CDI, pickup or engine.
                                Unless someone else wants to chime in, I can't see what else it could be.
                                The fueling shouldnt be far off.
                                • BluestoesonnoseB
                                  BluestoesonnoseB
                                  Bluestoesonnose
                                  If it's running lean or seems to be at high revs, there are five simple things to try.
                                  Float level, is it getting enough fuel?
                                  Tank cap, is the vent blocked or partially blocked cause fuel starvation?
                                  Fuel tap, is it opening fully and is it and it's filter clean?
                                  There is an inline filter in the brass pipe in the top of the carb, is it blocked?
                                  Air filter, is it very dirty or over oiled as too much fuel is as bad as too little?
                                  2002 DT125R
                                  • P
                                    P
                                    Pablo13
                                    #27
                                    All good ideas there thanks 😉
                                    Float level was set when I changed the needle stop as it was pissing out fuel from the carb when I got the bike, but sadly the problem was present before.
                                    Tank cap Is a good shout, Ill take a look at that and the filters once the fuel level gets lower.
                                    Air filter is new and not particularly over oiled, but again its been doing it with this one and the previous filter so can rule them out.
                                    Ordered a new coil, HT and cap anyway. Possible the one on the bike is 25 years old, so cant hurt 🙂
                                    • P
                                      P
                                      Pablo13
                                      Should also add that the bike revs freely to the red line when in neutral with no load.
                                      • P Pablo13
                                        @Pablo13 That rules out somethings, but the real test is under load. That's where the problems will become apparent.
                                          stinkwheelerS
                                          stinkwheelerS
                                          stinkwheeler
                                          i would definitely whip the cylinder off and see whats going on for the sake of a new piston and small end and a gasket set ... probably would have been my first shout and check for wear around the ports if you have tried everything else but it does sound like a electrical or cdi issue ... 240 main is best for dtr if you are running a aftermarket exhaust but its a tad rich so i always run without a snorkle never had a problem in the rain ect ....
