  3. Carburetor
  4. What's missing here?
35 Posts 7 Posters 10.1k Views 1 Watching
  • P Pablo13
    Its not the valve. I took the exhaust off and aligned the valve, unplugged the servo and it was still the same at the top. What should I look at next?
    @Pablo13 Cool, you're getting the same issue then?
    Have you done a plug chop? What's the fueling saying? You running snorkel in or out? How old is the spark plug. Is it the correct plug?
    How old is the ignition system?
    Is the air filter clogged up?
    • P
      P
      Pablo13
      wrote on last edited by Pablo13
      Yeah still going flat in the higher rpms. Maybe the coil is weak. No plug chops yet, but I stuck a new one in a few weeks back ngk 8 i believe. Also along with a new air filter as it just ticked over 24km.....about 15k miles. Snorkel is in. Problem has been there before the service too. Would be nice to get to the bottom of it 🙂
      • P Pablo13
        @Pablo13 Cool, fueling bone stock. Bike isn't modified?
        It might be just a tired engine. Low compression and piston blowby.
        • P
          P
          Pablo13
          Just an aftermarket exhaust and a 240 main jet I stuck in, that's it. So compression test next?
          • P Pablo13
            @Pablo13 What exhaust you running?
            Most manufactures stipulate sticking with 210 main jet, despite the uprated exhaust.
            I don't know the figures that constitute acceptable levels for the compression test.
            I would look at the electrics first.
            If the engine sounds sweet, then chances are it is.
            • P
              P
              Pablo13
              Rino Racing or something similar the exhaust is.
              So check over the coil next?
              • P Pablo13
                @Pablo13 Yeah something isn't right. But 93, if it's the original electrics, then I'd swap out the coil, and HT lead for a new one.
                If it's still causing issues then it can only be the CDI, pickup or engine.
                Unless someone else wants to chime in, I can't see what else it could be.
                The fueling shouldnt be far off.
                • BluestoesonnoseB
                  BluestoesonnoseB
                  Bluestoesonnose
                  If it's running lean or seems to be at high revs, there are five simple things to try.
                  Float level, is it getting enough fuel?
                  Tank cap, is the vent blocked or partially blocked cause fuel starvation?
                  Fuel tap, is it opening fully and is it and it's filter clean?
                  There is an inline filter in the brass pipe in the top of the carb, is it blocked?
                  Air filter, is it very dirty or over oiled as too much fuel is as bad as too little?
                  2002 DT125R
                  • P
                    P
                    Pablo13
                    #27
                    All good ideas there thanks 😉
                    Float level was set when I changed the needle stop as it was pissing out fuel from the carb when I got the bike, but sadly the problem was present before.
                    Tank cap Is a good shout, Ill take a look at that and the filters once the fuel level gets lower.
                    Air filter is new and not particularly over oiled, but again its been doing it with this one and the previous filter so can rule them out.
                    Ordered a new coil, HT and cap anyway. Possible the one on the bike is 25 years old, so cant hurt 🙂
                    • P
                      P
                      Pablo13
                      Should also add that the bike revs freely to the red line when in neutral with no load.
                      • P Pablo13
                        @Pablo13 That rules out somethings, but the real test is under load. That's where the problems will become apparent.
                          stinkwheelerS
                          stinkwheelerS
                          stinkwheeler
                          i would definitely whip the cylinder off and see whats going on for the sake of a new piston and small end and a gasket set ... probably would have been my first shout and check for wear around the ports if you have tried everything else but it does sound like a electrical or cdi issue ... 240 main is best for dtr if you are running a aftermarket exhaust but its a tad rich so i always run without a snorkle never had a problem in the rain ect ....
                          • P
                            P
                            Pablo13
                            So I fitted a new coil. Its a little better but still not quite right. Gets to 9700 now before going flat, but still feels like a little step around 9 where it tails off. I checked the carb and I think someone has previously removed the filter as I cant see one in there. I've got an o-ring coming for the tap so will wait until it comes then check that out too. Then I guess its time for a compression test, but I'm not expecting anything out of the ordinary because it runs sweet everywhere else.
                            How much is one of these zeeltronic jobbies then? 🤓
                            • P Pablo13
                              @Pablo13 Which country do you live in dude???
                              You can but direct, dependent on whether or not they ship to that country;
                              http://www.zeeltronic.com/page/aprilia.php
                              Or off good ole ebay;
                              https://www.ebay.co.uk/itm/CENTRALINA-APRILIA-RS125-1996-2011-PROGRAMMABILE-CDI-IGNITION-ZEELTRONIC-MOT-122/271194690954
                              • P
                                P
                                Pablo13
                                #33
                                I'm in the UK.......just see the price, lets hope it's not that 😄
                                • P Pablo13
                                  @Pablo13 PJME sell them, I recently got one for my RS.
                                  I bought my DTRE Ignition from Skellerns Cheltenham years back. They ordered a bunch in and I got mine for £160.
                                  Failing that you could get ignitech CDI's.
                                  The price is still cheaper than an OEM one new from Yamaha.
                                  • MightymanM
                                    Just to chime something else in, my TDR doesn't really have much past 9-10k either, but it seems to be due to a small hole where my silencer meets the expansion chamber. Whenever I patch it up, I get much more pull up the top of the rev range. Sadly my fixes don't last long 😪
