DTR 200cc ignition map
Tuning
15
Posts
4
Posters
3.9k
Views
Guessing RE with 200R engine
Hi,
thanks for the replies.
It's actually a YZ but running an 05 DTRE engine & loom/CDI but strokered & bored to 212cc.
I'm going to run Zeeltronic but I'm away ATM so I was looking for ideas of what sort of ignition timing curve to use.
Thanks.
Thank you, Calum. Static angle should be whatever Borut sets the RE at as I'm using the RE stator & flywheel. Timing light is at 17 degrees at Idle which is right.
I'm not getting a reply from Borut for some reason.
no one feeling charitable?
