  3. DTR 200cc ignition map
15 Posts 4 Posters 4.6k Views
  • NottsbikerN
    NottsbikerN
    Guessing RE with 200R engine
    • R
      R
      rs_raz
      Hi,
      thanks for the replies.
      It's actually a YZ but running an 05 DTRE engine & loom/CDI but strokered & bored to 212cc.
      I'm going to run Zeeltronic but I'm away ATM so I was looking for ideas of what sort of ignition timing curve to use.
      Thanks.
      • R rs_raz
        Hi,
        Thanks.
        @rs_raz More importantly, you'll need to find out what the static angle is.
        • R
          R
          rs_raz
          Thank you, Calum. Static angle should be whatever Borut sets the RE at as I'm using the RE stator & flywheel. Timing light is at 17 degrees at Idle which is right.
          I'm not getting a reply from Borut for some reason.
          • R rs_raz
            @rs_raz Cool so you are using the DTRE bottom end then?
            • R
              R
              rs_raz
              Except the crank, yes.
              • R rs_raz
                @rs_raz And the woodruff key exists in the exact same position as it does on the RE crank. Which is my point. Otherwise no, your static angle is not correct.
                • R
                  R
                  rs_raz
                  I was worried about that too but I measured with a degree wheel and used a timing light and the woodruff key is in the right place.
                  • R
                    R
                    rs_raz
                    Well thanks for the replies anyway.
                    MiniaM 1 Reply Last reply
                    • R rs_raz
                      MiniaM
                      MiniaM
                      Minia
                      @rs_raz Sorry mate, best of luck to you.
                        Yeah it's difficult, not actually having a DTR200 I can't really help. Besides mapping really ought to be done by someone who knows what they're on about. I could share a map that melts your piston, and you wouldn't be too impressed!
                        • R
                          R
                          rs_raz
                          No worries. I will start with the RE curve and go from there ☂
