  3. DTR 200cc ignition map
15 Posts 4 Posters 4.2k Views
  • R Offline
    R Offline
    rs_raz
    Hi guys,
    Can anyone with ~200cc's please share their ignition map with me?
    I'm running the stock DTRE timing and getting a lot of preignition.
    Thanks 🙂
    • R Offline
      R Offline
      rs_raz
      😢 no one feeling charitable?
      • M Offline
        M Offline
        Minia
        What bike have you got? A DTRE or a DT200R? You're a little short on information.
        • NottsbikerN Offline
          NottsbikerN Offline
          Guessing RE with 200R engine
          • R Offline
            R Offline
            rs_raz
            Hi,
            thanks for the replies.
            It's actually a YZ but running an 05 DTRE engine & loom/CDI but strokered & bored to 212cc.
            I'm going to run Zeeltronic but I'm away ATM so I was looking for ideas of what sort of ignition timing curve to use.
            Thanks.
            • R rs_raz
              Hi,
              Thanks.
              @rs_raz More importantly, you'll need to find out what the static angle is.
              • R Offline
                R Offline
                rs_raz
                Thank you, Calum. Static angle should be whatever Borut sets the RE at as I'm using the RE stator & flywheel. Timing light is at 17 degrees at Idle which is right.
                I'm not getting a reply from Borut for some reason.
                • R rs_raz
                  @rs_raz Cool so you are using the DTRE bottom end then?
                  • R Offline
                    R Offline
                    rs_raz
                    Except the crank, yes.
                    • R rs_raz
                      @rs_raz And the woodruff key exists in the exact same position as it does on the RE crank. Which is my point. Otherwise no, your static angle is not correct.
                      • R Offline
                        R Offline
                        rs_raz
                        I was worried about that too but I measured with a degree wheel and used a timing light and the woodruff key is in the right place.
                        • R Offline
                          R Offline
                          rs_raz
                          Well thanks for the replies anyway.
                          M 1 Reply Last reply
                          • R rs_raz
                            M Offline
                            M Offline
                            Minia
                            @rs_raz Sorry mate, best of luck to you.
                              Yeah it's difficult, not actually having a DTR200 I can't really help. Besides mapping really ought to be done by someone who knows what they're on about. I could share a map that melts your piston, and you wouldn't be too impressed!
                              • R Offline
                                R Offline
                                rs_raz
                                No worries. I will start with the RE curve and go from there ☂
