  4. Cases
Cases
31 Posts 7 Posters 6.9k Views
    Can't see this reply properly as it comes up blurry.
    @Bluestoesonnose The images? Yeah it's hosted through Flicker, or from Google.
    But if you google.
    Yamaha TZR 125 RR Belgarda SP Barrel
    You should see exactly what I'm talking about. I've spoken to people who've ridden the SP engine and they say it's sublime.
    Personally, it's no better than a Rotax 122 engine && Costs substantially more.
    So just transplant a Rotax engine, or get a better bike.
    The 4FU, again costly, is a more viable options.
    in the end, I just spent a little money on the 3MBP barrel, but wasn't impressed with the results against a STOCK RS.
    • BluestoesonnoseB
      BluestoesonnoseB
      Bluestoesonnose
      So these things are a direct swap on the DT cases
      2002 DT125R
        I'm confused by all the codes, remember I'm only learning about these engines atm
        @Bluestoesonnose That's why I've linked you a video. The 4FU can be found on the European 4GW Belgarda TDR models.
        Google and Search should help you find what you're after.
        Yes they're direct swap.
        • BluestoesonnoseB
          BluestoesonnoseB
          Bluestoesonnose
          So this one
          292776003728
          https://www.ebay.co.uk/itm/YAMAHA-TZR-125-R-TZR125-R-4FU-USED-CYLINDER-BARREL/292776003728?hash=item442acf4890:g:kUUAAOSwjmFbQ1I1:rk:1:pf:0
          2002 DT125R
          • BluestoesonnoseB
            BluestoesonnoseB
            Bluestoesonnose
            No idea what Rotax motor your on about though
            2002 DT125R
              @Bluestoesonnose Rotax 122 barrel. £20
              https://www.ebay.co.uk/itm/Aprilia-RS125-Mitaka-Barrel-1991-2011-Rotax-122-And-123-RS-125-Spares-Or-Repair/192690108309?hash=item2cdd39b795:g:0UMAAOSwaIJbdEd3:rk:7:pf:0
              And the difference between that, and an SP barrel is negligible, yet you'll pay £500 with an SP barrel.
              Yes that one is the 4FU, but you will need the 4FU powervalve to suit.
              • 2
                2stroketerry
                Hi @Bluestoesonnose I have a spare 4FU00 barrel with the powervalve if you want will post some photos, just make an offer as no use to me as Athena 170 kit on my DT
                • BluestoesonnoseB
                  BluestoesonnoseB
                  Bluestoesonnose
                  I could be interested as I've just discovered that my spare barrel is FUBAR as it's got a crack in it
                  2002 DT125R
                  • 2
                    2stroketerry
                    Hi, photos of the 4FU barrel with powervalve fitted, you can see the bore is scored
                    so will need replating or reboring. Just make me an offer if any good to you.
                    0_1541473310223_1.jpg 0_1541473326104_2.jpg 0_1541473340116_3.jpg 0_1541473348850_4.jpg 0_1541473359147_5.jpg 0_1541473368648_6.jpg 0_1541473375261_7.jpg
                    • BluestoesonnoseB
                      BluestoesonnoseB
                      Bluestoesonnose
                      Hi,
                      Looks good to me, no idea what the going rate is for one, ummm £75 posted?
                      2002 DT125R
                      • 2
                        2stroketerry
                        Hi @Bluestoesonnose £85 posted ?
                        • 2 2stroketerry
                          @2stroketerry 85s a good price
                            Hi,
                            BluestoesonnoseB
                            BluestoesonnoseB
                            Bluestoesonnose
                            Hi, sorry to say I got offered one for £50 all in so I've bought that.
                            Thanks anyways
                            2002 DT125R
                            • 2 2stroketerry
                              To get DT to pull a lot harder should of fitted Athena 170 kit rather than a ported 125 barrel, have got a ported head and barrel off Mick and the 170 is miles better with the extra torque and being 20 stone the torque makes so much difference. My 170 is fully ported and revs to over 11,000 on a 2003 DT R using standard TM 28 carb with the powerjet blocked and standard air filter with snorkel on.
                              People who say ports are 3mm to low don't know anything about tuning as when mapped the ports and they are 125 ports and same hieght as 125 ports. The reason they don't rev past around 8,000 or so is because of the exhaust port width as on 2 strokes exhaust port width has to be a certain percent of the bore diameter, so going from 56mm bore to 65mm bore totaly screws up the engine. Exhaust port width limit is 73% of the bore diameter (measured straight across). So 56mm bore is 41mm and the 65mm bore can be opened up to 47mm.
                              Double check the pv cable setting on Athena kit as with holes lined up standard the powervalve is only 3/4 open, on mine set powervalve in cylinder flush then drilled a new 4mm hole in center of powervalve pully.
                              Engine tuning is all about everything working together and a combination of ports, compression, carb, ignition all perfectly matched. With the Athena kit most people run wrong plugs to suit it best like br9es or a br9eix irridium plug. The plugs to use on any ported DT are NGK B10EG non resister plugs along with 7mm HT lead copper core and a non resister plug cap.
                              The bottom end makes cruising more relaxed, and the extra top end means it'll now do a wheelie in 4th gear easy.
                              sprintall84
                              @2stroketerry what’s top speed you had out of your dt with the 170 kit on ?? Coz A few people saying there no good get a 4fu00 barrel and head ??
                              • S sprintall84
                                @sprintall84 It's not necessary speed you benefit from, but more torque. So gear it appropriately you should be fine.
                                As a general whole, the Athena kit isn't brilliant. A 3MB00SP Barrel is what you want. But the price for those is astronomical.
                                4FU is a decent barrel which is plated rather than steel liner. This benefits from better heat transfer. But draws back from expensive repairs. Ultimately the DT is limited.
                                A decent spec'd Athena 170 should top out at 100mph. Plenty for a 125.
                                • T
                                  T
                                  theportingmaster
                                  Here is my ported 170 athena when first fitted it using standard gearing and went off the clock. Fitted an Athena exhaust and a 34mm polini carb with top of air box cut out to it after this video, did 110mph with an 18t front sprocket but really scary on nobbly tyres,lol😵
                                  https://www.youtube.com/watch?v=8a_sBkpuQ14
                                  S 2 Replies Last reply
                                  • T theportingmaster
                                    sprintall84
                                    @theportingmaster is that your dt in the YouTube clip ??
                                      jonne123
                                      That 110 is really fast closer to over 30hp
                                        sprintall84
                                          sprintall84
                                          @theportingmaster you got any 170 barrel and head for sale ??
