Dt125r died In the cold
Woke up this morning went outside to start my beloved dt... kicked over lovely for about 2mins or so then all of a sudden she died.. which was no fuel.. put the reserve tank on and fired up again just fine but when I went to give her a bit of throttle she began to run biggy and died... tried again and seem as if it flooded and will not start at all now... checked the plug has spark have good compression.. do not no where to begin.. any ideas would be maybe fuel to air mixture or idel screw setting please.. someone help
Do you use reserve often? Could be blockage or more likely crap at bottom of tank turn fuel tap off and drain carb, refill in normal position, worth a try
