  4. Somethings leaking :/
18 Posts 6 Posters 2.4k Views
    @jakeyboy Also the black oil is burnt engine oil, I would check that all engine bolts are securely tightened up to their correct torque settings. And the carb fixings on the rubber pipes and manifold as well. Personally I would replace all gaskets with the Athena ones, as with everything in life quality does not come cheap and buying cheap products usually costs you in the long run. :winking_face:
    I would also check that you exhaust is not leaking anywhere too. And in your second pic you have different bolts holding on the water pump cover. Which would give different levels of sealing. It would be worth replacing all of those with bolts which are all the same. Cheap Stainless steel bolt kits can be purchased off ebay and are well worth the investment in the long run. Along with a Haynes manual too, both are essential bit's of kit which will save you a lot of money!!! πŸ˜‰ :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
    jakeyboyJ
    jakeyboyJ
    jakeyboy
    wrote on last edited by jakeyboy
    @NINJA thanks for the help appreciate it, already purchased the bolt kit so should be arriving soon and about to get new gasket set. Will be sorting that out when it arrives and also got some new reeds coming so will be a good opportunity to check all the bolts on manifold and carb. Also I have a 2005 Yamaha DT X, would this be ok as I’m aware they are fairly similar. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F361287660164
    • jakeyboyJ
      jakeyboyJ
      jakeyboy
      https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F152642149627
      These look alright?
      CalumC Irongamer727I 2 Replies Last reply
      • jakeyboyJ jakeyboy
        These look alright?
        @jakeyboy I tend to buy my gaskets from PJME rather than eBay.
        But each to their own.
          These look alright?
          @jakeyboy why buy a whole gasket set?
          jakeyboyJ 1 Reply Last reply
            jakeyboyJ
            jakeyboyJ
            jakeyboy
            @Irongamer727 cheaper than buying individually and less hassle
              @jakeyboy I believe that the DTR and DTX share the same engine, maybe with some slight differences, but the Haynes manual will give lots of help with basic maintenance. And the Athena gaskets look good, it's always better to start off with a full set, as that way if you don't use em all you will have some spares for the future. πŸ˜‰
              You can download the manuals for free, but having a hard copy is always handy;
              See here;
              https://dt125r.co.uk/topic/579/downladable-dtr-re-x-manuals
                See here;
                jakeyboyJ
                jakeyboyJ
                jakeyboy
                @NINJA sound, thanks. Just ordered πŸ™‚ had a brief look through the online manuals and haven’t seen anything regarding torque settings for the bike. Any idea where I can find this?
                Cheers
                  Cheers
                  jakeyboyJ
                  jakeyboyJ
                  jakeyboy
                  @jakeyboy oops, had another look and found some measurements but nothing for engine casing torque & exhaust. Much appreciated!
                    @jakeyboy There normally at the front of the Haynes manual.
                      @jakeyboy due to oil being thin when hot the force of the wind can push the oil all over the place
                        jakeyboyJ
                        jakeyboyJ
                        jakeyboy
                        @declan thanks for clearing that up πŸ™‚
