  4. Somethings leaking :/
18 Posts 6 Posters 2.2k Views
  • jakeyboyJ jakeyboy
    Hi, recently brought a Dt in September and Iโ€™m fairly new to the dismantling and fixing side of engines but like to think Iโ€™m not completely useless as fitted a kickstarter mech and a few other basic changes to the bike.
    Got back from a ride and noticed there was oil all over the bottom of my casing and also my coolant was leaking from the pump. The oil and coolant has seem have just gone straight through the gaskets. (Shitty eBay set for like a 10r which I now know are useless) they lasted a month but thatโ€™s it... just wondering if something else it leaking like the head and wanted another point of view before I end up replacing all gaskets. Because looks a bit of an odd place for oil to be if itโ€™s just the right side of engine.alt text
    Added a few photos (I think)
    Any helps appreciated ๐Ÿ™‚
    @jakeyboy bad clutch cover gasket maybe?
    jakeyboyJ 1 Reply Last reply
      jakeyboyJ
      jakeyboyJ
      jakeyboy
      @Irongamer727 yes thatโ€™s what I was thinking but wondering why the oil managed to get so far up the casing at the front? Or would this be normal. Cheers
      • Glynn123G
        Glynn123G
        Glynn123
        I've used the cheap gasket kits off eBay on mine, they have all worked great apart from the head gasket, throw that straight in the bin.
        • Glynn123G Glynn123
          jakeyboyJ
          jakeyboyJ
          jakeyboy
          @Glynn123 thinking of getting the more pricey Athena full kit from eBay, should be better
            @jakeyboy Athena gaskets are about the best quality ones you can buy ATM!!! ๐Ÿ˜‰
              @jakeyboy Also the black oil is burnt engine oil, I would check that all engine bolts are securely tightened up to their correct torque settings. And the carb fixings on the rubber pipes and manifold as well. Personally I would replace all gaskets with the Athena ones, as with everything in life quality does not come cheap and buying cheap products usually costs you in the long run. :winking_face:
              I would also check that you exhaust is not leaking anywhere too. And in your second pic you have different bolts holding on the water pump cover. Which would give different levels of sealing. It would be worth replacing all of those with bolts which are all the same. Cheap Stainless steel bolt kits can be purchased off ebay and are well worth the investment in the long run. Along with a Haynes manual too, both are essential bit's of kit which will save you a lot of money!!! ๐Ÿ˜‰ :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
                jakeyboyJ
                jakeyboyJ
                jakeyboy
                wrote on last edited by jakeyboy
                @NINJA thanks for the help appreciate it, already purchased the bolt kit so should be arriving soon and about to get new gasket set. Will be sorting that out when it arrives and also got some new reeds coming so will be a good opportunity to check all the bolts on manifold and carb. Also I have a 2005 Yamaha DT X, would this be ok as Iโ€™m aware they are fairly similar. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F361287660164
                • jakeyboyJ
                  jakeyboyJ
                  jakeyboy
                  https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F152642149627
                  These look alright?
                  CalumC Irongamer727I 2 Replies Last reply
                    These look alright?
                    @jakeyboy I tend to buy my gaskets from PJME rather than eBay.
                    But each to their own.
                      These look alright?
                      @jakeyboy why buy a whole gasket set?
                        jakeyboyJ
                        jakeyboyJ
                        jakeyboy
                        @Irongamer727 cheaper than buying individually and less hassle
                          @jakeyboy I believe that the DTR and DTX share the same engine, maybe with some slight differences, but the Haynes manual will give lots of help with basic maintenance. And the Athena gaskets look good, it's always better to start off with a full set, as that way if you don't use em all you will have some spares for the future. ๐Ÿ˜‰
                          You can download the manuals for free, but having a hard copy is always handy;
                          See here;
                          https://dt125r.co.uk/topic/579/downladable-dtr-re-x-manuals
                            See here;
                            jakeyboyJ
                            jakeyboyJ
                            jakeyboy
                            @NINJA sound, thanks. Just ordered ๐Ÿ™‚ had a brief look through the online manuals and havenโ€™t seen anything regarding torque settings for the bike. Any idea where I can find this?
                            Cheers
                              Cheers
                              jakeyboyJ
                              jakeyboyJ
                              jakeyboy
                              @jakeyboy oops, had another look and found some measurements but nothing for engine casing torque & exhaust. Much appreciated!
                                @jakeyboy There normally at the front of the Haynes manual.
                                  @jakeyboy due to oil being thin when hot the force of the wind can push the oil all over the place
                                    jakeyboyJ
                                    jakeyboyJ
                                    jakeyboy
                                    @declan thanks for clearing that up ๐Ÿ™‚
