  3. Other
  4. Project SMX [Pic Heavy]
276 Posts 16 Posters 177.7k Views 4 Watching
    Hy Mec - How you doinggg???
    She took a bit of setting up and after several bleed's, a full strip down and rebuild of the slave cylinder I have finally got her working. I can't wait to test her out for real, but first impressions is that the clutch is buttery smooth to operate!!! :grinning_face_with_smiling_eyes: :face_with_stuck-out_tongue_winking_eye: :grinning_face_with_smiling_eyes:
    I had to modify the clutch arm to follow the curve on the clutch case, as the arm would not pull the clutch cam lever properly otherwise and it also stopped the cam lever from retracting back as well;
    I re-used the OEM clutch cable and cut off the end, as it has a rather nice double oil seal on it. Plus it moves the slave cylinder away from the clutch case, thus providing room for the oil pipes to neatly tuck behind it. I also cut a piece off the plastic protection sleeve and used that to join the slave cylinder to the old clutch cable. I also found a U shaped bracket I had lying around which was nearly a perfect fit to secure the slave cylinder. I just used a longer bolt and added some washers to keep it all secure.
    After some adjustments I was able to get her working really well, I will only know for-sure once the engine is running and I can test the gear shifting out properly, as the Rotax engine does not seem to like shifting up and down the gears without the engine running. As I had some problems with the grip shift mechanism sticking whilst testing the Hymec. So I had to remove the clutch case and strip the grip shift down, to clean it all up, re-grease it all and reassemble it to stop it sticking. But after much fannying around and tweaking she seems really solid now, but the true test will be with a running engine, so it's TBC..................
    #204
    The angled inlet manifold for the 34mm Dellorto carb finally arrived, 3 weeks from Italy via the Donkey express!!!
    It's designed to fit the stock reed block, so some mods were called for. Once I had cut off the reed flange, I set about port matching it as best I could to the new Italkit Carbon reed block;
    She's not perfect, but it is lovely and smooth, I feel that it turned out pretty good, so she's all ready for fitting now, along with that shiny 34mm Dellorto carb I purchased some months ago.
    :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
      yeah that's looking sweet bud!
        Louis-DT-WRL
        Louis-DT-WRL
        @NINJA loving the attention to detail! Good work!
        • Louis-DT-WRL Louis-DT-WR
          @Louis-James Thanks man, I'm just following in your footsteps!!! :grinning_face_with_smiling_eyes: :winking_face: :smiling_face_with_open_mouth_closed_eyes: :face_with_stuck-out_tongue_winking_eye: :grinning_face_with_smiling_eyes:
            Louis-DT-WRL
            Louis-DT-WRL
            @NINJA easy to get carried away but feels good knowing everything is 100%
              @Louis-James Peace_of_mind is a wonderful thing for-sure!!! :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: 🤗 :smiling_face_with_heart-eyes:
              • NINJAN
                WOOP WOOP - The airbox upgrades have arrived;
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @NINJA said in Project SMX [Pic Heavy]:
                  Fun times... Everyone loves the postman bringing new bits 😁
                  • NINJAN
                    #212
                    Air box upgrades are installed and I test fitted the box, here's the before and after pics;
                    Hopefully that will help suck in a bit more air along with the larger 34mm carb of course!!!
                    :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :grinning_face_with_smiling_eyes:
                    • NINJAN
                      That's a wrap!!! 😁😎😁🏍💨
                      Before;
                      After;
                      • NINJAN
                        #214
                        The 34mm Dellorto carb is fitted and I also fitted those other parts back on too, she's coming together nicely now;
                        I added the Tail tidy and wired her up, I need to order some new indicators as the one's I have look to big IMO;
                        And I test fitted a few parts as I was dying to see how she was coming along;
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          It's always very satisfying at this stage 🙂
                          Good work!
                          • NINJAN
                            #216
                            Another 10mph gained!!!
                            • NINJAN
                              #217
                              A small update;
                              I got you pegged - Slippin n' Slidin!!! 🏍💨😁😎😜
                              • NINJAN
                                #218
                                Boy Oh Boy - Where does the time go. Well finally after having to save up for some parts and then wait for them to finally arrive, progress has now been made.
                                New parts fitted;
                                Hel Braided Carbon brake lines.
                                New Galfer & Goldfern Sintered brake pads.
                                Stock Calipers back on.
                                Lithium Ion battery.
                                Scalvini front pipe.
                                FP mid pipe.
                                Tyga Carbon rear silencer.
                                I had to readjust the Magura slave cylinder, as it's a tight fit on the Scalvini front pipe, but it all fits good now. I think the front pipe needs protecting so I'll look into that. More parts are on the way so hopefully there is some light at the end of the tunnel now!!! :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
                                  That pipe looks savage.
                                  Coming together nicely!
                                  What is the eta for completion.
                                    @Calum Thanks bud, ASAP is the best estimation I can give ATM. I'm hopeful of being able to ride her this summer, if all go's to plan. I think I'm gonna see how much it will cost to get the exhaust chromed to keep it looking shiny. I have some other parts to fit and I need to get the wheels refurbed, new decals and some other bits n' bobs. But most of the big expenses are now out of the way now. I have a new set of Conti-Attack SM Evo's to go on her as well, so I'll keep plugging away until it's BRAP BRAP Brap time!!!
                                    • NINJAN
                                      #221
                                      I started preparing the wheels by stripping the paint off and rubbing them down, so that I can respray them;
                                      • NINJAN
                                        #222
                                        Wheels all prepped and ready for respraying:
                                        Primer and 2 top coats applied;
                                        Final top coat sprayed on today;
                                        They turned out really good for a rattle can job, so I'm very happy. I'll let the paint harden for 48 hours and then give them a quick buff up and apply 2 coats of Lacquer to seal them, which will also hopefully maintain their freshness too.
                                        • NINJAN
                                          #223
                                          Wheely good rattle can spray job complete, all ready for some rubber now; 😁 🏍💨 😎
