Another New Guy
@NINJA said in Another New Guy:
@d3cme Your water temp sensor may be knackered? Which is a possible cause to your problems, but it sounds like you have another problem causing the restriction. Is the power valve set up correctly? Has the YPVS (?) air bottle been removed? It's number 35 in this pic, it comes off the intake between the carb and air filter box;
https://www.fowlersparts.co.uk/parts/4171936/dt125r-3rmm-2002-050-b/intake
I can’t see anything missing but not sure I can see that part exactly.. will need to strip it back a bit more to see for sure I think.
While I was looking I’ve got 2 ports on the carb without anything on, I got some pics and will look on that site to see if I can see the same view for the carb and work out what they are.
@d3cme You can't miss it dude, it sits against the frame next to the air filter cover, aka that black bottle between the fuel tap and the sprocket;
Take and post a pic of your bike the same as the pic I posted above please dude.
I deffo don’t have that! I’ve got the bracket now I know where it sits... can’t see where it would connect on that elbow though?
@d3cme said in Another New Guy:
The elbow on mine looks like the alternate ‘19’ in the diagram. Not sure what it means though? No YPVS? different YPVS?
@d3cme That's fine, older DTR's don't have that bottle. I removed it from my DTRE and used an older style boot. Eventually deleted it entirely by using a pod filter.
@Calum said in Another New Guy:
When you say older though, mines a 2002 so later DTR, but early if compared to DTX/DTRE I think? Looks like it’s how it should be as opposed to obviously missing something though.
@d3cme But it's not UKDM so who knows.
What I mean is, that not all DTRs came fitted with those bottles.
@d3cme My DTR was a 2002 and when I removed that boost bottle the bike did not accelerate as fast, plus I lost 10mph off the top speed. As soon as I put it back on the bike was fast again. Now having no bottle may not affect Rpm's but it did slow the bike down. However if the CDI is mapped for a boost bottle, then surely the lack of one would affect the bikes performance???
Sadly no change still having moved the Reed Switch well out of the way.
Think I'll whip the exhaust off later and check there is a powervalve in there lol
@d3cme There are restrictions in the exhaust front pipe too, which can only be removed by cutting it open and welding it back up. A straight swap to an aftermarket exhaust is easier and may be cheaper too.
Is there a way of checking? I think I saw that the 2002's have it in the larger part of the exhaust as opposed to immediately in the neck? Will I need a new gasket? I'll borrow a borescope in and see if I can make anything out.
Seen some bits about flipping the PV 180 degrees? Any truth in that?
@d3cme You can remove the front pipe and literally stick your finger up it
To feel for any restrictions, or use the borescope as you've suggested. OEM's build bikes to meet omission laws etc and therefore have restrictions in place whereas aftermarket parts remove those restrictions. It's just like the Catalytic converters on cars, they create a honeycomb/blockage like effect to slow the gasses down. Remove the cat and the gasses flow out quicker.You would be better off just getting a new pipe like a DEP, Giannelli, Arrow etc. And keep your stock one if you ever come to sell it, as most of the restrictions are in the exhaust. Or if you want the ultimate in looks and performance then go for a Romeu pipe;
As they are not only hand made but they will outperform, outlast and look simply amazing on any DTR, as well as adding value. Personally I would not waste any more effort on this, just follow the derestricting guidelines, order that bad boy and be a happy biker 24/7!!!
Thanks All,
I think a certain amount of this is managing my expectations. I used it for work today and it was great, I think its just not got the 'kick' I was expecting from the YPVS. I'll have a look at the PV tonight and take the exhaust off to see whats what!
I was actually eyeing that exhaust up earlier @NINJA, looks very nice!
@NINJA Stock pipe. The amount of weight saved by going aftermarket is probably where 90% of the noticeable power comes from I swear!
The FMF on my DT200WR is like a feather in comparison to the stock one which weighs a tonne!
Go after market every time
@Nottsbiker DAMN I forgot about the FMF - great pipes too!!!
