  4. Oil from Crankcase breather and won't rev out
7 Posts 4 Posters 753 Views
  • B Offline
    B Offline
    Barrelman
    Just imported 1989 dt125r. Now on the road but engine cuts out at about 8k revs. Checked YPVS valve which operated fine. Carb stripped and cleaned all good. However still won't rev out. Very occasionally it will rev almost to redline but mostly it cuts out (stutters). It's also kicking oil out of breather. Any suggestions
    • DanRacingD Offline
      DanRacingD Offline
      DanRacing
      @Barrelman said in Oil from Crankcase breather and won't rev out:
      Bad crank seals most likely
      • B Barrelman
        NINJAN Offline
        NINJAN Offline
        @Barrelman I concur with Dan. ;)
        • B Offline
          B Offline
          Barrelman
          Thanks for replies. Now to work out how to do that. Always learning
          • B Barrelman
            NINJAN Offline
            NINJAN Offline
            @Barrelman Grab yourself a Haynes manual off ebay dude, there worth their weight in gold. ;)
            B 1 Reply Last reply
              B Offline
              B Offline
              Barrelman
              @NINJA said in Oil from Crankcase breather and won't rev out:
              Reading it as we speak
              • NottsbikerN Offline
                NottsbikerN Offline
                Reassemble is simply the reverse of the disassembly procedure.
                That's a gem from Haynes and about ad helpful ad an ashtray on a motorcycle ;)
