  4. 1988 bike
1988 bike
139 Posts 9 Posters 74.2k Views 1 Watching
    Old school carburettor
      Not easy finding correct needle, no UK source I could find, Wemoto do a aftermarket kit for the tzr (keyster brand) was going to be my only option as closest available, found correct part at csmnl but postage for one part expensive. Had to have it though, original needle deformed at tip. spent this eve fitting oil pump and Water pump, cleaning up carb heater spigots on cylinder head. Found some decent used rad hoses in my box of spares, trying to keep all original.
        @oldman Looking good my friend. :clapping_hands_light_skin_tone:
        @NINJA said in 1988 bike:
        Thank you!
          Still haven't done the swingarm bearings though, keeps slipping my mind😨
          • O oldman
            @oldman wish my linkage bushing would lol it’s holding up the whole project
              Cleaned and removed bearings, then noticed gouge in swing arm fork, looks like chain has been rubbing. Only minor really but want perfect finish so on to swingarm no 3, cleaned all the oil and grease off and looks OK, pivot bearing sound but main bearings shot, replacing those anyway. Weather permitting will be outside tomorrow removing my third set of bearings, just call me lucky
              • O oldman
                #64
                @oldman damn how many swing arms you got lol half a mind to come and borrow a few
                  This is the last one I have, if this fails will have to resort to eBay 🙁
                  • O oldman
                    @oldman how’d you get on? How much play do you allow on your linkage
                    O 1 Reply Last reply
                      @declan said in 1988 bike:
                      Swingarm bearings replaced and relay arm bearings all cleaned and regreased, pivot bushes excellent on swingarm no3 so no play in it at all, 3rd shock was also good both ends with no play and good compression damping. Put together yesterday and happy with assembly, started front forks today, overfilled and smelt like pond water
                        Also toying with idea of fitting progressive fork springs, anyone tried them with a dt? Did fit a set years ago to a 600 and made a big improvement to that, but chalk and cheese really?
                        • O oldman
                          @oldman beautiful
                          • O oldman
                            @oldman Progressive springs are on my phase 2 upgrade wish list for my MX, If I had kept my DTR I would have fitted Wirth progressive springs to it. There are quite a few reviews out there, so a Google search is well worth the effort to be more informed. I found these 2 to be quite illuminating tho;
                            https://motorbikewriter.com/progressive-linear-springs/
                            https://www.xt660.com/showthread.php?t=19823
                            It appears that rider weight and riding style affect the progressive springs more as the forks become compressed. AKA Greater compression increases the stiffness of the forks. Obviously the heavier the rider the more pre-load is placed on the forks, ergo more compression. And if you're an aggressive rider then the same stiffness applies, during the increased bouts of fork compression. The true test would be to ride 2 identical bikes other than standard springs vs progressive springs and then you will have an instant comparison.
                              @NINJA
                              Thanks for that, read both and still undecided🤔
                              Don't find the suspension on the red bike wanting TBH, ordered new seals and bushes Inc oil. Probably stick with the originals and change later if I feel I have to.
                                Have ordered the jet needle I need 3 times now (fowlers, csmnl, yamaha France) and each time after a few days have elapsed receive a message saying not available and refund issued (all advertising for sale). Tried Allen's with no joy and only option is aftermarket one for TZR125 same era, one digit off correct part no compatibility. Any suggestions? Mikuni round slide btw.
                                • O oldman
                                  @oldman The stock needle? I guess it's just an old carb right? Still seems odd not to have it anywhere.
                                    Tried yamaha UK customer services and last one listed as sold in 2013!. Did order aftermarket kit for tzr from Wemoto that lists needle jet one digit off dt one, still waiting for that 1 week on. Will keep looking but only hope seems to be picking up nos one on eBay eventually, or complete new carb from csmnl for lots of dosh.
                                    • O oldman
                                      @oldman Have you tried the FB groups or known DT breakers???
                                      https://dt125r.co.uk/topic/562/parts-suppliers-database/5
                                        @NINJA trying for new to be honest, had some s/h bits already that are below what I wanted. My reasoning being if it's new as specified it can't be wrong, too fussy that's my problem!
                                          Have not posted an update for a while, progress is slow (its summer!) Forks rebuilt and calipers prepared, headlight, instruments and handlebars fitted, loads of other small jobs done. Waiting on brake caliper piston and bleed nipples. Wheels need rebuilding soon so need to sort a decent pair for that. Finally received a carb needle that should do the job (tzr), ordered correct one 3 times from different suppliers and refunded 3 times when they did not have one. Pictures to follow.
