  4. Clocks
Clocks
10 Posts 5 Posters 722 Views
  • declanD Offline
    Is there any way to get into the clocks on the dt specifically the speedo the back side of the screen needs cleaning or is it possible to replace the screen,TIA
      No they are sealed as far as I am aware.
        @Calum what is it with Yamaha making sealed systems lol
          NINJAN Offline
          NINJAN Offline
          @declan You would be better advised buying a new set off Aliexpress;
          https://www.aliexpress.com/item/32958409291.html?spm=a2g0o.productlist.0.0.65fc6a5agfwUJp&algo_pvid=a2740523-c1d9-4cf6-bfe5-989fcf014937&algo_expid=a2740523-c1d9-4cf6-bfe5-989fcf014937-2&btsid=4a3b6fc1-343f-4e06-bc34-cf3aed310023&ws_ab_test=searchweb0_0,searchweb201602_1,searchweb201603_52
          declanD 2 Replies Last reply
            @NINJA I’m pretty sure they need modifying for the wiring to work though don’t they?
              @NINJA I’ll see if my lights work when I build the bike back up if they don’t I’ll get a set thanks for the link
                NINJAN Offline
                NINJAN Offline
                @declan Speak to @Louis-James he fitted some to his DT200WR.
                • M Offline
                  M Offline
                  mhbikesnbits
                  Is there’s a will there’s a way lol pretty sure they are sealed tho probs not advisable to try
                  • NottsbikerN Offline
                    NottsbikerN Offline
                    I'd look around for another set of clocks.
                    My DT200WR came with kmh clocks which I've swapped the speedo unit for one from a DT125X which are mph for £40 used
                    • NottsbikerN Nottsbiker
                      NINJAN Offline
                      NINJAN Offline
                      @Nottsbiker £40 is an absolute bargain, I paid £120 for mine!!!
