  4. No spark!
No spark!
53 Posts 6 Posters 10.0k Views
    So I’ve tried everything I’ve checked every wire that I have messed with tried 3 different spark plugs and still nothing, the only thing I can think that has happen is I’ve un done the wires that delete the side stand switch or something similar I have a bunch of spare wires some of which were joined together I’ve been trying them together with no luck
    I’ve been thinking, even if my kick stand circuit was bad I should still be getting spark in neutral right? Would the bike still spark if the whole ignition barrel was in plugged
    clawsC 1 Reply Last reply
      clawsC Offline
      clawsC Offline
      claws
      @declan the bike stops getting a spark after you put it into gear if your kickstand circuit is disconnected. it should work on neutral though. i really suggest checking the wiring and taking a look at the stator or measuring the amount of volts with a multimeter while starting
      • clawsC claws
        @claws it all worked before I took the engine out, weird thing is I’ve checked all the wiring I have tampered with it has a brand new ignition barrel and I’m suspecting it’s faulty although the pv does cycle when key is turned
        N 1 Reply Last reply
          N Offline
          N Offline
          @declan It's most likely either something is not connected properly, an earth is missing, or a blown fuse? Have you checked all those dude???
          • N NINJA
            @NINJA there’s no fuse fitted no earth was removed the 4 wires I had to snip and re fit are in good order with new connectors I’m a lil lost
              N Offline
              N Offline
              @declan Did you take any photo's of the bike pre/mid disassemble? If yes then refer back to them and look for any differences between the old & new installations.
              • N NINJA
                @NINJA the wires are colour coded and I marked every wire that was important to the starting and running of the engine
                declanD 2 Replies Last reply
                  @declan so to rule out a few things, will the dt start without the ignition barrel,will the neutral circuit cause problems if the wire is not looped, would the clutch circuits also cause problems if it’s not looped
                    https://imgur.com/a/opX7k1M
                    I found these wires wrapped up two of them are joined together I can’t remember if there were other joined like this, they come from the same loom as the battery wires
                      Okay, looks like the problem is the ignition coil when I remove the wire and kick the bike it shocks me yet when I connect it back up the plug still doesn’t spark I already have one on order so I’ll update when I’ve fitted it...(edit- by remove the wire I mean the direct feed from the cdi to the ignition
                        N Offline
                        N Offline
                        @declan Are there any breaks in the wire, which could be causing a short circuit???
                        • N NINJA
                          @NINJA nope, just seems the coil went dead
                            N Offline
                            N Offline
                            @declan OK well hopefully a new coil will resolve the issue???
                            • N NINJA
                              @NINJA it should do
                              • N NINJA
                                @NINJA never that simple is it 😕 I have power before the coil but when connected up I get nothing
                                  N Offline
                                  N Offline
                                  @declan Are you sure that the correct wires are connected to the right terminals bud???
                                  • N NINJA
                                    @NINJA yeah just as the original was, it will shock me every time but the second that power wire touches the ht terminal the power vanishes
                                      N Offline
                                      N Offline
                                      @declan It sounds like you have a short somewhere else? Re-check all the wires as something is a miss.
                                      • N NINJA
                                        @NINJA I can’t find anything wrong it doesent make any sense I could understand if it was weak power but no power at all is flowing through
                                          N Offline
                                          N Offline
                                          @declan Well something is causing the issue, try using a volt meter to check volt's & Amps etc
