  4. No spark!
No spark!
53 Posts 6 Posters 11.6k Views
    @NINJA how do I go about testing things I have my multimeter now
    @declan Look in the Haynes/Owners manual there should be a list of voltages. You then just put one probe one each wire and check your readings against the ones listed.
      @NINJA hi, I have looked but I’m not familiar with wiring in general I don’t know which ones I’m supposed to be testing
        #25
        @declan The ones to the coil would be the first place I would look. Then check any other wires associated with the ignition system. I suspect that you have something either not connected correctly or an earth is failing? Scrape some paint off underneath the ground eyelets to ensure that you have a good earth, as a bad earth will cause a short circuit and give you problems. 😉
          From experience the earths are prone to fail on old looms, check continuity using your multimeter from various places. Have you unwrapped the loom around coil area? Definitely worth checking, look through my red bike posts and you will see I had to renew earth from that area. Earth cable oxidised internally and started intermittently failing and quickly failed altogether .
          • O oldman
            @oldman I figure it has to be the stator because when I hold the power wires coming from the stator I get a decent shock but when I do the same but on my 50cc the jolt is easily 4or 5 times more powerful
              @declan Dude you've gotta stop trying to electrocute yourself!!! :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣 🤣 🤣
                Anyone recommend a flywheel puller for the dt?
                  @declan I think wemoto sell this part. Worked for me.
                  Provided you are talking about DTR.
                  I have got the generic puller off the eBay and that has never let me down. Used if on countless of stuff.
                    @Calum is that the little cylinder type or the one with the two arms, and which size is yours providing you can remember
                      @Calum Do you have a link please???
                        https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F192815216901
                        Is the generic type I used on my RE engine.
                        https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F264446694058
                        Is one similar to the DTR one.
                          @Calum Thanks bud. :thumbs_up_light_skin_tone: :thumbs_up_light_skin_tone: :thumbs_up_light_skin_tone:
                            @Calum thanks, so my Haynes only mentions the resistance tests for my charging and lighting coil but I’m not interested in them why is there no info on the source coil
                              At 2k ohms on my dtr stator I’m getting .822, on my dtx stator I’m getting .223 this is measured at the source coil Haynes checked and it tells me the dtx stator is good but the dtr stator is very bad, unless I have done something wrong it’s looking like I’m after a new source coil
                                Do you guys reckon the re/x stator set up would fit the dtr
                                O 1 Reply Last reply
                                  @declan said in No spark!:
                                  Can you send me a picture of what you need? I have some spares that might help.
                                  • O oldman
                                    @oldman I need the entire stator set up, I was wanting just the coil responsible for the spark but on my year that can’t be replaced
                                    • O oldman
                                      @oldman https://imgur.com/a/KsJbbFi
                                        @declan
                                        Will have a rummage tomorrow in my storage unit (swamp)
                                        • O oldman
                                          @declan
                                          @oldman spare part bins are the best and thanks
