  3. Exhaust
  4. Giannelli vs stock
Giannelli vs stock
51 Posts 5 Posters 13.0k Views
    jonne123
    Should i buy used giannelli exhaust and silencer. Does it increase power?
      Stock derestricted is a good pipe.
      I went from that to DEP and besides the weight difference, I noticed a good power difference.
      J 1 Reply Last reply
        jonne123
        @Calum So do you recommend the giannelli and what about sound?
        CalumC clawsC 3 Replies Last reply
        • J jonne123
          @jonne123 I have never used that pipe i'm afraid.
          • J jonne123
            clawsC Offline
            clawsC Offline
            claws
            @jonne123 yes it's a good exhaust. i recommend it and i can at some point link a sound check
            • J jonne123
              clawsC Offline
              clawsC Offline
              claws
              @jonne123 there you go
                jonne123
                Do i need to adjust the carburator if i install giannelli?
                clawsC 1 Reply Last reply
                • J jonne123
                  clawsC Offline
                  clawsC Offline
                  claws
                  @jonne123 bigger main jet. do you have a stock carb?
                    jonne123
                    Yes. What is good budget exhaust and it is worth buying? Power increase?
                    declanD clawsC 2 Replies Last reply
                    • J jonne123
                      @jonne123 all of them offer a power increase however if you want budget and power then gut your original exhaust
                      • J jonne123
                        clawsC Offline
                        clawsC Offline
                        claws
                        @jonne123 ask your some motorcycle facebook group if they can sell a performance exhaust for dt125
                          jonne123
                          But i have full power 1994 that hasnt any restrictions?
                          • J jonne123
                            @jonne123 Probably won't be that much in it then over a budget pipe. Usually it's the weight of the stock pipe that does it.
                            Bang for buck in my experience, is swapping the ignition system out for a Zeeltronic.
                            But I have no experience with the 94 CDI.
                            Tuning is an art, and not a single component on its own will make that much of a difference. But getting a collection of supporting mods will.
                            What head are you running? The earlier ones ran the restrict 3BN head. And having that changed will make a difference. 3MB heads came factory fitted to the later models, but are getting hard to come across these days. Having the restriction removed would cost less than finding a decent 3MB head. Talking £35 to have the head modified.
                              jonne123
                                jonne123
                                does athena silencer fit stock pipe?
                                  jonne123
                                  @Calum how is the head supposed to be modified?
                                    There is a combustion ring on the 3bn head. That needs removing.
                                        jonne123
                                        Does athena silencer fit stock exhaust?
                                        • J jonne123
                                          @jonne123 i should imagine it would although i had an old dep on my big one and when i switched to the new dep i had to enlarge the dep pipe to fit the expansion chamber so who knows
